Question about Kenmore Dryers
Dryer works for only a few seconds but then shuts off
I recently had my basement flooded and my dryer got a lot of water in it. It will work for a few seconds if I hold down the start switch but then it seems to trip a circuit breaker in the dryer somewhere. If I hold down the start button for about 5 seconds you can smell a hot smell coming from the bottom of the dryer. I tested the start switch and one of the fuses with a DMM and they tested fine. I took the motor out and saw some corrosion from the water and I cleaned it off, then reinstalled the motor and it's still doing the same thing. This is a relatively new dryer so everything should still be working except for the water that got into it may have done something to it but I can't seem to find the source of the overheating.
  • rgagen76 May 14, 2009
    There's no water anywhere in the dryer, I turned the think upside down and felt inside the vent but no moisture at all. The burning smell does come from the vent area though. It does seem like the safety shut off clicking. I wonder if there is a short somewhere on the motor or something causing too much voltage to get to the motor and tripping the safety shut off...
  • 77 Answers
You probably still have water collected and trapped in the vent somewhere leading to the safety shutoff. I would unplug it and remove any connections to the dryer and then turn the unit upside down to see if any more water drains out of it that was trapped.
Posted on May 14, 2009
Roper dryer red4400sq0
The heating elements and the motor would have gotten wet with that much water. You need to disassemble it and check both.
Jul 07, 2013 | Whirlpool Dryers
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
My drier was in a foot of water during a recent flood in my basement. Is it salvagable? If so, what would likely need to be replaced?
If this was a gas dryer; absolutely not. Electric can be more forgiving if it is allowed to dry out. Gas appliances become a safety issue because of damage to the gas valve.
Aug 10, 2010 | Maytag MDG2706A Gas Dryer
I have a kenmore front loader dryer. My basement recently had a flood and the bottom of the dryer was wet. When i tried to start it, it hums but will not run. What is the problem?
the motor is cooked,i live in the boston area and we had some bad floods a few months ago,all i did for two weeks was change out dryer motors,you can try to spin the drum and hold in the door switch and have someone else hold in the start button to see if it will start but you have to change out the dryer or get a new one if it's in rough shape
Aug 05, 2010 | Kenmore 73952 Gas Dryer
Hi. My mother had a flood in her basement recently and although her 5 year old ge Profile gas dryer was set up on blocks off of the floor the bottom section got wet and it had stopped working. The...
you need to inspect the ignitor/glow coil that ignites the gas in the burner tube as they are very fragile,then on the burner tube body check the radint sensor eye it can be dirty,clean it first or then replace it,the gas valve boost and secondary coils on the gas valve could have been damaged and they keep the gas valve open to supply gas to the burner,then also check the thermal fuse on the vent blower housing as water could have ruined this component,also check all wire connections for water corrosion too
Jul 07, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
