Question about ASUS A8S-X Motherboard
Not recognizing hard drives
Hi I have an asus A8S-X motherboard and I have taken out my old IDE hard drives and put in 2 new Sata drives, My pc will boot up but it will not recognize my second drive and when I go to CMOS it shows them as 3rd master & 4th master drives, whats going on here.
Thank you very much,
My name is Tony Le-Clezio and my email is  playloud@bigpond.net.au
Thanks again. Tony.
This motherboard only supports SATA 1 and is not good at the step back feature that SATA 2 has for backward compatability.
If you have SATA 2 drives, see if the your drives have a jumper to set the to 150Mbps transfer rate for backward compatability with SATA 1.
If you have SATA 1 drives or PATA drives you may be dealing with the partition/format problem mentioned above.
Posted on Aug 08, 2008
    Scholar:
  • 59 Answers
It sounds like your hard drive might not be formatted.  If the hard drive supplied a utility to do this you might try it.  If not you can do it through windows xp.
http://www.ehow.com/how_6026_format-hard-drive.html
There is a link to some basic instructions of how to format the drive in windows.
Posted on Oct 16, 2007
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
MY PC IS NOT BOOTING AND DISPLAYING MESSAGE ''NTLDR IS MISSING''?
Missing NTLDR file.
To repair missing orcorrupted system file/s, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4482455-repair_windows_xp
May 22, 2011 | ASUS P5GZ-MX Motherboard
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
As I stated earlier I have ASUS K8S-MX Motherboard, but when I connect IDE 80GB drive with 500GB SATA drive it does not detect my 4 SATA partitions, instead says it is only 500GB unformatted single...
Check your AHCI (or ACHI, can't remember) settings in your BIOS. Turn them off, use "standard pata mode" even though you're using a SATA drive, and try again.
Dec 18, 2009 | ASUS K8S-MX Motherboard
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
Dec 13, 2009 | ASUS K8S-MX Motherboard
ASUS M2N MX SE Motherboard
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Jun 18, 2009 | ASUS M2N-MX Motherboard
K8V-MX motherboard+HDD size limit
yes the mother board supports SATA However if you connect large Disks to the SATA connectors they are recognized correctly with full size. So leave your 500g and less HDs on the IDE and the big ones on the SATA. you can check this link for the manual for more information ftp://ftp.chiligreen.com/Desktop/Manuals/manual_a_k8v-mx.pdf hope this helps .thanks and Godbless pls appreciate by rating as fixyaa
Oct 03, 2008 | ASUS K8V-MX Motherboard
Sata and IDE hard drive
hi there,
yes your motherboard would allow this .. once you configure in the bois your boot drive being the IDE drives ....the operation of the other drives should be a breeze ...
Apr 27, 2008 | ASUS P4S8X Motherboard
Sata hard disk drive on asus p4v8x-x motherboard
i think you should install via raid tool from asus driver cd then check in control panel --> administrative tools--> computer management and you click to disk management
the sata hd will dectected by the computer so you can format it
you must reboot first after via raid tool instalation
i manage this way and succeed on my 500 gb sata drive
try it
Jan 28, 2008 | ASUS P4V8X-X Motherboard
ASUS A8S-X Motherboard Logo
207 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
