Question about RCA L26HD31 26 in. LCD HDTV
Picture is white with sound
My tv has sound but no picture
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
I have sound from my DVD player but picture is from the cable show how do I fix and make them both the tv sound and picture or dvd sound with picture, what settings
take sound from audio out from back of TV rather than from back of DVD player.
Move the red and white rca cables to the audio out of the TV
Jan 18, 2017 | Televison & Video
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
White picture.
Sounds like you have the White Pattern turned on. Find your documentation for your TV and look it up. Should be an easy fix.
Apr 12, 2009 | Astar LTV-19BG TV
No sound or picture on my prima plasma tv
I HAVE A NICE PICTURE BUT NO SOUND
Sep 30, 2008 | Prima CV2011 TV
RCA L26HD31 26 in. LCD HDTV Logo
153 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
