Question about Car Audio & Video
What type of globe do i need and how do i relace the globes for radio button display in 97 volvo v70
  • the old fart May 14, 2009
    as i dont have a manual that covers this problem i will take it to the dealer for rectification tah for the thought. eric
  • the old fart May 17, 2009
    thanks for the thought sandy guess i expected too much i will look after the problem. please delete me from fixya. eric
  • 952 Answers
Just contact the dealership, they will be able to give you a part number. Just try to describe the part that you need replaced.
Posted on May 18, 2009
    Sergeant:
    Champion:
  • 219 Answers
Hi, well u need to check the manual for this.Manual contains the step by step process of doing it.
Thanks! Sandy
Posted on May 14, 2009
  • Sandeep Gupta May 14, 2009
    well in that case u need to take it to vendor!
    Thanks!
    Sandy
I need replacement globe for light kit.
If it is the type with the triangle shaped base there are only two types available direct from Hunter. I replaced the entire light kit on mine when the globes started to fail due to excess heat and the tips of the triangles started to break off causing the globes to fall at random.
Apr 19, 2016 | Hunter Dryers
Hi. Please help i cant use Globe network as my internet for my HTC Wildfre. Please help the correct settings of mobile network. thanks
1. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names
2. Click Menu->New APN and follow the setting below (leave settings as is for those not mentioned)
  • Name: Globe Internet
  • APN: http.globe.com.ph
  • APN type: default
3. After saving the settings above, select the newly created APN (green radio button appears).
Your phone is now configured to use the newly created APN.
May 04, 2011 | HTC Wildfire Cell Phone
Model: 16ULW/ET-24218 nothing displays, nothing works
I have a different model, but it had the same problem. I plugged it in and used a paperclip to press the "reset" button. After a click, probably a mechanical relay, the display appeared, and it worked.
Nov 25, 2010 | Globe Electric Globe Indoor/Outdoor Lights...
Globesymbol display on my phone
If the globe symbol is displayed it denoted that your phone is using the active data connection..
Check whether you have any software that uses the internet is running, also try switchin off the phone and switching on the phone..
Press and hold the RED button continoisly so that the phone DATA connection gets disconnected..
Pease leave me comment,if you need any further assistance
OR please rate this solution
Thanks
Dec 20, 2009 | Cell Phones
Volvo radio not working in rear of car
Need to check out our wiring for an short,maybe an loose wire somewhere..
Mar 10, 2009 | 2002 Volvo V70
Radio code 1998 volvo v70
your going to have to call up your local volvo dealer and give them your vin number and they can look it up for you. You can try using radio-code.com but i wouldnt recomend it. Your best bet is calling your local volvo dealer and they will help you out.
Feb 21, 2009 | 1998 Volvo V70
Olympia, and/or Sharper Image infoglobe. Need fix.
It appears that you have already removed the 4 screws. The globe will not just fall off, it has to be pried. Take a small- bladed screwdriver or a small-bladed pocket knife and gently pry from any small opening you see between the globe and its base. Work the blade around the globe and it will come off. I just did it and now I'm trying to figure out how to get inside the "guts" of the globe. Will keep you advised.
Dec 27, 2007 | Olympia InfoGlobe Cordless Phone ol3020
Blank display
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Sep 26, 2007 | Yamaha RX-V870 Receiver
Blank infoglobe
Noise? Louder than normal motor noise? The display is created by the revolving LED board that is connected to a motor. It should be quiet unless you pick it up and give a good listen. Let me assume that you mean that it is normal noise, indicating that the unit is turning. Unplug the power as well as the phone lines from the unit. First, remove the plastic globe. There are 4 points that the globe is connected, two towards the rear and two in front on either side of the control buttons. Press the globe at the front ones and lift towards the rear. After you have removed the globe, remove the three screws that hold the rotor (looks like an "L") to the motor shaft. The LED display is soldered to the rotor. These solder joints break and need to be re-soldered. By adding a small amount of heat as you are bending the display slightly inward, you can repair the connections. Only use low watt solder gun! Re-attach the rotor and globe (unit will not spin with globe off) re-connect the power, press the select button and check out the display. If all connections were made, you will have succeeded. If a line or two are missing, try again!
Jan 26, 2007 | Wave Industries OLY-OL3000 Globe Phone
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
