I stop of using My Bose CD player for while then when I turn it on at won't work I check all connections make sure everything plug right, is there any fuse that may be goes bad?
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
SOURCE: Bose 321 won't play CD and VCD but plays DVD
I did have the same problem. Then unplugged / replugged the base cable (= also the power supply) and after this the Bose dis play CD's again.
SOURCE: Problem with my Bose 321
I had the same problem listed; send an email to BOSE tech support - they sent me a DVD with a bios upgrade and it fixed the problem. They should put the BIOS upgrade on their website so you could burn your own DVD rather than waiting for the mail. But it did fix the problem. Netflix disks were the worst; they must do something when they burn them to get that forced Ad to play that Bose doesn't like.
