Question about Daewoo DVN-14F6N 13" TV
Constant static, even from line in, even when every input is unplugged. Recently resoldered a loose seating from RCA jack to board. Fixed the jack, but soon afterward the static began. Static occurs even in other rooms on separate circuits, no other CRT in the house gets static. When in standby, the speaker hisses.
  • 4 more comments
  • a_da_bertie May 14, 2009
    A cursory inspection revealed no obviously blown capacitors, and the only place where static is not present is the tv's menu, so the problem must be somewhere between line in/cable and the CRT.
    After leaving the TV on for a while, the static gets less intense and the hissing gets quieter. Heat is probably affecting the component in question, so it may still be a faulty capacitor.
    Where could I go to have the components checked? Or, how do I check them myself to determine which to replace? More likely to happen, where could I find a complete replacement board?
  • a_da_bertie May 15, 2009
    The TV is a Daewoo DVN 14F6N, 14" from 1998.
    Sorry, 13".
  • a_da_bertie May 21, 2009
    Thanks so much, very good source!
  • Daewoo Master
  • 19,396 Answers
You can buy full service and repair manual with all TV schematics from one fo the links below:
Service Manual Daewoo DVN-14F6N TV
Daewoo DVN-14F6N TV_VCR IN ONE BOARD REPAIR Manual
Just click that purchase button on the bar at left, after opening websites above.
Do not forget to leave feedback.
Many thanks.
Posted on May 20, 2009
  • 916 Answers
It sounds like the tuner needs to be replaced
Posted on May 19, 2009
  • 952 Answers
Check the capacitors near the CTV circuit area... try to change them if possible
  • Daewoo Master
  • 3,866 Answers
The solder you used is not the recoomeded solder that is used to repair this type of compnet there are diffrent grades of solder and this is causing you interference beleave it or not I been in the repair biz for 20 years and try lots of grade solder, try a diffrent grade solder use Wicking wire is what i call it to de solder this and re solder with a light reson low flux solder.. This will shore this right up in a heart beat!! I used to sit on the QC team for Sony and RCA and beleave me we had issues with things like this as welll as I have personally.. Hope this helps and Hope you do rate me for my time...
Thanks Rulds2008
Posted on May 15, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Try to use a grounded power supply so that the static current is grounded. If it doesn't have three prong cable then you can connect a cable to the body of the tv and can insert that into the ground connection on the wall socket.
If using a 3 prong grounded cable doesn't help then it is a faulty/leaky capacitor on the reciever/tuner board of your Tv and there are chances that you might need to get it replaced. As replacing the tuner board can solve the problem completly whereas, replacing a component on tuner board can return the static problem.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 14, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith May 14, 2009
    Hi
    Try using a RCA component cable or a different cable and also please try to use a grounded wall socket.
    Thanks
    Rylee
  • Rylee Smith
    Yes its the leaky capacitors which after getting powered up for a while don't produce much static. Also get your power supply transformer and capacitors checked.
    Thanks
    Rylee
  • Rylee Smith
    Please tell me the make and model number of your TV so that i can provide you with model specific information.
    Thanks
    Rylee
My deville has just stopped producing any sound what soever. All the tubes glow and the red power light is on but no sound. I have tapped the sides of all the tubes and they all register a sound except the...
The first thing i would do is not leave it on in this way for too long. You could blow out a very expensive Transformer if its a faulty speaker. The worst thing you could do to a TUBE amp is run it without a speaker . I would test the speaker first. Just remove the wires going to it. And connect the speaker to either a car stereo or house system at low volume very low. And see what you get. if it works ? Good! Now check your guitar chord/wire. Try different ones try different guitars. If that doesn't work . Look into the input jack on the instrument input hack on the amp.. They do come loose off the board.Either get a new input jack or resolder the old one. if you only have one guitar look at the guitar output jack. Loose wiring on the guitar could cause this also. Dirty In and out put jacks could cause this. A pencil with Very fine sand paper wrapped around it will clean a dirty input/output jack. Try these things. Just remember poking around your amp is Dangerous. The electrical components hold a charge even unplugged that can kill you. No joke..
Dec 26, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Garmin nivi 200 won,t turn on
The mini-USB jack needs to be either resoldered or replaced. When the jack is loose, you will not be able to charge the internal battery. The jack becomes loose from overuse. The jack needs more mechanical support to the pronted circuit board. I have fixed this problem many times.
- Jim
Aug 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Cambridge A5 Amp, only one speaker works when phono selected
If both speakers work okay on other inputs .Then cable from pre-amp to amp and main amp are okay. If phone RCA jacks go directly to electronics board .Then its possible solder on phono jacks need to be resoldered or other connections in that section.If unit needs repair you can also purchase a phono preamp from radioshack hook up your and use it on other good inputs such as CD etc..Please note PHONO inputs are only for turntables .If a non turntable input such as CD,TAPE,TV Etc is used on PHONE .Then you will overdrive this input .
Jul 21, 2009 | Audio Players & Recorders
Tha yellow rca jack is broke off into my tv can u please help mefix this
you would have to take the board out and resolder it back on, but there should be another input on there, some even have them on the front, i would just use a diferant one, but if thats the only one, you wil have to solder it
Jan 07, 2009 | Televison & Video
No video on VIDEO 2...cold solder connections on video and audio inputs...resolder, but solder pad for video has no connection ...looking for a pictorial view of the PC board to insure there is a...
I just fixed this on my TV. With the small front input board removed from the tv, solderside up and the rca jacks pointing away from you begin.Looking at the board in this position locate RCA video jack. Directly in a row are 2 comparitively large solder pads. The pad furthest from the RCA jack and closest to you has a thin trace that runs from the noted pad to a solder pad on a small surface mount component marked 750. That small trace is not making contact on the solderpad that is soldered to the RCA jack. To fix it take a small metal pic or tiny flat screwdriver and scrape away some of the PC board coating right on the trace where it meets the solder pad, and place a small solder bridge on it. Thats it put it back together and watch TV. Thanks to all the members here who post solutions. Frank
Dec 01, 2008 | Sony KV-32S20 32" TV
Sound is just static
Don't understand why, perhaps rca contracted microsoft for their programming, but when I unplugged the TV and it rebooted, everything is fine. I still am concerned about the warning on the back.
Apr 20, 2008 | RCA P52930BL 52" Rear Projection...
Constant static and interference
FIRST YOU MUST DETERMINE IF THERE IS STATIC ON YOUR PHONE LINE. EVEN WITH DSL THERE CAN BE STATIC EVEN IF THE INTERNET IS WORKING. IF YOU HAVE A CORDED PHONE TAKE IT OUT TO THE PHONE INTERFACE BOX AND OPEN THE BOX / THERE SHOULD BE A PLACE YOU CAN UNPLUG YOUR WIRING FROM THE PHONE COMPANY. PLUG YOUR PHONE INTO WHERE YOU UNPLUGGED THE WIRING AND SEE IF YOU HAVE STATIC THERE. IF YOU STILL HEAR STATIC IT IS THE PHONE COMPANY'S PROBLEM.
SOMETIMES UNPLUGGING FROM BOTH THE PHONE LINE AND THE POWER SOURCE AND REMOVING THE BATTERIES WILL CORRECT SOME PROBLEMS. FOR SECOND PHONES ON A SYSTEM THEY MUST BE REGISTERED TO THE BASE. ONCE IT IS REGISTERED IT SHOULD SHOW A NUMBER IN CORNER OF SCREEN (2)
THE MANUAL SHOULD TELL YOU HOW TO REGISTER SETS. IF YOU HAVE LOST YOUR MANUAL SEE IF YOU CAN DOWNLOAD ONE FROM THE WEB SITE OR CALL VTECH 1-800-595-9511
Dec 05, 2007 | Vtech 5.8GHz Analog Cordless Phone
Horizontal Lines and Blue Tint on my Sony KDP 57XBR2
ok,your porblem is very simple,reheat or resolder the main board your tv.
Oct 22, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony KV- 32V35 Front Jacks
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Aug 31, 2007 | Sony KV-32V35 TV
*HELP* No Picture, Turns on, No Pic whatsoever.
you didnt mention if your audio is o.k. if has no video and audio the problem is in the flyback? yoke? HV section. i need to check it personaly. post more forum so i can determine the problem.
Dec 29, 2006 | Samsung TXN2771HF 27" TV
Daewoo DVN-14F6N 13" TV Logo
136 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
