Question about Microsoft Computers & Internet
I try to open Microsoft excel 2003 that was not open, it goes to preparing to install and ask 7zs3as tmp file. (Yesterday I cleaned my registry and temproary flies by a software Cuperutilities disk cleaner.
    Champion:
  • Microsoft Expert
  • 401 Answers
Similar problems are very bad, but luckily i have quite big experience for working out such problem. The next software would be useful here - Excel recovery tool.
Posted on Apr 27, 2011
Not open excel
Posted on May 14, 2009
Solution for Excel 2003 "the file is not in a recognizable format"
If you open an excel created by M/S Office 2007, Excel 2003 will not be able the file. You have to install Microsoft Office the "Compatibility Pack for Word, Excel, and PowerPoint File Formats" for M/S Office 2003 from Microsoft Site.
or
Your Excel file is corrupt!
Hope it helps.
Oct 01, 2010 | Computers & Internet
Htmlmarq.ocx unable to register in systems registry
Open regedit and browse to this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options
You should see htmlmarq.ocx and htmlmm.ocx separate keys. Rename them to something else, ie. htmlmarq.tmp and htmlmm.tmp.
You will now be able to install Office 97, including the HTML option, without incident.
Mar 05, 2010 | Microsoft Word 97 Upgrade Version for PC
Opening file problem
There may be compatibility problems. Do a repair using add/remove programs. There may be problems with COM components also. Right click on my computer icon and go to manage. From there go to Event viewer snap-in. There are logs for office softwares. Examine that. If there is an error it will be listed there.
If this is helpful to you, please rate. Thank You!!!
Jun 15, 2009 | Microsoft Office Excel 2003 for PC
How to recover the windows server2003 (missing file c:\ windows\system32\config\system
Two options:
Either reinstall Windows
OR
Follow the procedure below
It will be better if you print these instructions since you will need to type many commands later. I'm typing a detailed procedure to recover your windows.
It's possible that somehow your Windows registry is corrupted. But there is a backup. Only thing is you need to manually restore it.
Boot using your Windows XP cd in the drive and press enter when it asks to boot from CD (if it does not ask, then you will need to go to the CMOS setup by pressing DEL or F2 key and change the boot sequence)
Now, when booting from 2003 CD, it asks if you want to do a recovery, press R and you will get this screen:
Microsoft Windows(R) Recovery Console
The Recovery Console provides system repair and recovery functionality.
Type EXIT to quit the Recovery Console and restart the computer.
1: C:\WINDOWS
Which Windows Installation would you like to log onto
(To cancel, press ENTER)?
Type 1 and press enter.
Now type the commands I am putting below, one by one per line and press enter after every line.
md c:\tmp
cd system32\config
copy system c:\tmp\system.bak
copy software c:\tmp\software.bak
copy sam c:\tmp\sam.bak
copy security c:\tmp\security.bak
copy default c:\tmp\default.bak
del system software sam security default
Now, type these commands: (Take care to type the dot as it is)
copy c:\windows\repair\system .
copy c:\windows\repair\software .
copy c:\windows\repair\sam .
copy c:\windows\repair\security .
copy c:\windows\repair\default .
Now type exit and press enter and the system will reboot.
Remove the CD and boot normally in Windows .
If the PC boots in to windows, then do the following:
Start Windows Explorer.
On the Tools menu, click Folder options.
Click the View tab.
Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the "Hide protected operating system files (Recommended)" check box.
Click Yes when the dialog box is displayed that confirms that you want to display these files.
Double-click the drive where you installed Windows XP to get a list of the folders. It's important to click the correct drive.
Open the System Volume Information folder. This folder appears dimmed because it is set as a super-hidden folder.
This folder contains one or more _restore {GUID} folders such as "_restore{87BD3667-3246-476B-923F-F86E30B3E7F8}".
Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RP x under this folder. These are restore points.
Open one of these folders to locate a Snapshot subfolder; the following path is an example of a folder path to the Snapshot folder:
C:System Volume Information_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}RP1Snapshot
From the Snapshot folder, copy the following files to the C:\tmp folder with the mouse:
_registry_user_.default
_registry_machine_security
_registry_machine_software
_registry_machine_system
_registry_machine_sam
Now, once again put your Windows 2003 CD in to your CD Drive and reboot using the CD. Again press R for the recovery console.
At the console, type these commands one by one per line and press enter after every command:
cd system32\config
del sam security software default system
copy c:\windows\tmp\_registry_machine_software system
copy c:\windows\tmp\_registry_machine_system system
copy c:\windows\tmp\_registry_machine_sam sam
copy c:\windows\tmp\_registry_machine_security security
copy c:\windows\tmp\_registry_user_.default default
Now type exit and remove the CD. Boot normally in Windows and you must be back to normal.
If in case, Windows doesn't boot even following this procedure, then you need to reinstall windows. BUT you can still try a repair install instead of a normal install since that will let your programs and settings remain as they are, intact.
Post back and I will reply with that procedure.
HTH,
Regards,
Deboo
Feb 14, 2009 | Microsoft Windows Server Standard 2003 for...
I am having problem opening my microsoft excel files.
Is Office installed or not? Here is a free Excel viewer from Microsoft if Office is not yet installed: http://www.microsoft.com/downloads/details.aspx?FamilyID=c8378bf4-996c-4569-b547-75edbd03aaf0&displaylang=EN Post back if you still need assistance. Steve Medley
Dec 14, 2008 | Microsoft Windows XP Professional With...
Microsoft office 2007 excel problem when i save excel files then i coulnd not save a file , because there some tmp error
Just re-install the excel only using your ms office 2007. Once you put the installer on the drive it will give an option on what office you want to install, just select excel.
Thanks
Nov 25, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Outlook 2003 sycn with yahoo email
Windows 95, 98, and ME syntax
Deletes one or more files.
DEL [drive:][path]filename [/P]
ERASE [drive:][path]filename [/P]
[drive:][path]filenameSpecifies the file(s) to delete. Specify multiple files by using wildcards./PPrompts for confirmation before deleting each file.Windows 2000 and Windows XP syntax
DEL [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
ERASE [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
namesSpecifies a list of one or more files or directories. Wildcards may be used to delete multiple files. If a directory is specified, all files within the directory will be deleted./PPrompts for confirmation before deleting each file./FForce deleting of read-only files./SDelete specified files from all subdirectories./QQuiet mode, do not ask if ok to delete on global wildcard/ASelects files to delete based on attributesattributesR Read-only files S System filesH Hidden files A Files ready for archiving- Prefix meaning notIf Command Extensions are enabled DEL and ERASE change as follows:
The display semantics of the /S switch are reversed in that it shows you only the files that are deleted, not the ones it could not find.
Windows 2000 and Windows XP recovery console syntax
Deletes one file.
del [drive:][path]filename
delete [drive:][path]filename
[drive:][path]filenameSpecifies the file to delete.
Delete only operates within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
Del and delete do not support replaceable parameters (wild cards).
Examples
Notice: Users who are running Microsoft Windows 95 and are used to deleted items going to the recycle bin need to keep in mind that deleting files from MS-DOS does not send files to the recycle bin. del test.tmp = Deletes the test.tmp in the directory that you currently are in, if the file exists.
del c:windows est.tmp = Delete the c:windows est.tmp in the windows directory if it exists.
del c:windows emp*.* = (* is for wild character(s)) *.* indicates that you would like to delete all files in the c:windows emp directory.
del c:windows emp?est.tmp = (? is a single wild character for one letter) This command would delete any file ending with est.tmp such as pest.tmp or zest.tmp...
You may also configure your outlook express to auto delete Emails by creating a rule for them.
Illustration.
If you can not see the illustrations properly , youtube has excellent tutorials.
http://www.youtube.com/watch?v=wcb7x7ErtO4
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Microsoft Office Outlook 2003 for PC
Missing cab file etc.
There might be a problem with your ms excel, some files are corrupted and therefore you are unable to open your files..so the best solution is that we can repair your ms excel
for this just goto control panel > Double click on Add Remove Program >select microsoft office > now you will see a option change > just click on it and select Reinstall or Repair' ,on next screen it will ask you for 'Reinstall Office' or 'Detect and repair errors in my office Installation', first go with ''Detect and repair errors in my office Installation, if it doesn't help you go with 'Reinstall Office' ...........
I hope you are satisfied with my support regarding your issue.
It will be highly appreciated if you could take a minute and provide me your feedback.
May 13, 2008 | Microsoft Office Outlook 2003 for PC
PROBLEM OF PRO11.MSI
Go to start menu, run, then type 'excel' and hit enter, the installation menu will start but you can just cancel it. To me, the installation will start again and again but I cancel it as Book 1 excel already opens. Then you can double-click any excel file that you want and open it. It worked for me! :)
Apr 08, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Computers & Internet Logo
153 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
