Question about Epson Stylus CX3200 All-In-One InkJet Printer
The red light is on and the message scanner error. tried turning it off and then on again after a few seconds the red light comes on again. Also check to see if the system was locked released that. Tried to reset nothing.
  • 1 more comment
  • Anonymous Jun 11, 2008
    scanner error red light on
  • Anonymous Jun 12, 2008
    I tried turning off the printer and pressing reset but the button won't reset. I dont have documents on the printer to fix the problem. When I turn the printer back on it says scanner error.
  • BirchCrafts Sep 01, 2008
    I have exactly the same porblem. Toggling the lock/unlock switch hasn't helped.
Try flicking the transportation lock (on the left side under the scan lid) on and off. It has a picture of a pad lock shown locked and unlocked. Flip it back and forth and leave it in the unlocked position.
This worked for me. Good luck!
Posted on Oct 17, 2007
Everytime I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your...
when I turn my printer on (Epson Artisan 700 series printer) it waits for about 5 to 7 seconds and then displays a message that says "A scanner error has occured. Please see your documentation". Then all the lights start flashing, And then I cant do anything, but turn the printer off.
I have turned it off and unplugged it and tryed again always same result.
bdl12920@aol.com
May 10, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
2003 saturn vue service light on with wrench how do I reset
Open the hood. You will notice there is a large black box on the right-hand side directly behind the battery. This black box is the fuse box. Pull the top of the fuse box off. There are two clips on either side; once you pop one side, the other comes off very easily. In the top left-hand side of the fuse box where all the fuses sit, you will see a large orange/red block. Below this block is a button that says "reset." Press this button for 5 seconds. Turn the car on and wait for a minute. If the light does not go on, turn off the car and set the key to ACC on the key ring. Push the reset button again, holding it for a total of 15 seconds. Turn the key to off, take out the key, return the key and start the car again. Allow the car to run for 2 full minutes. It is taking the system a few minutes to register that this button has been pressed.
Sep 01, 2009 | 2003 Saturn VUE
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
KV-S2026C not scanning
does this unit show any error?
how old is this unit> is it under warranty?
Oct 02, 2008 | Panasonic KV-S2026C Pass-Through Scanner
Red light comes when powered
Please try the following to resolve your issue:
1. Unplug the USB cable and the AC adapter from the back of the scanner.
2. Toggle the Transportation lock (located on the bottom of the scanner) back and forth 5 times, ensuring that the lock is all the way in the unlock position.
3. Reconnect the USB cable and the AC adapter cable, and then try to scan.
Jan 04, 2008 | Epson 2580 Perfection Photo Scanner
Scanner error
Oct 07, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Scanner not responding to preview scan
Try this as a last ditch effort. Remove the software. Reboot the computer and come off line. Disable the Anti Virus program. Now install the soft ware. Then try. If the red light still flashes then assume it is new scanner time.
Jul 26, 2007 | Epson Expression 1640XL Flatbed Scanner
Error 5
I can't seem to find a error code 5. What software are you using to scan? Did the error start right after your first? Had the scanner been working?
Jul 12, 2007 | Kodak i40 Path-Through Scanner
Epson Stylus CX3200 All-In-One InkJet Printer Logo
533 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
