Question about D-Link High-Speed 802.11g Wireless PCI Adapter AirPlusXTREMEG (DWL-G520) (DLINKDWLG520)
Sharing internet from dlink 510g to linksys wap54g AP
Anyone experience to properly connect unit with internet connection sharing its internet thru dlink wirelessly to Linksys wap54g AP to another computer commonly laptop.
Is it possible to just install the driver after the PCI card has been installed and properly shares it internet connection?
  • fougzki May 14, 2009
    The setup is this, one computer both having a built in LAN that cater the wireless broadband and also have installed Dlink 510g a wireless PCI. And I think it is the one throwing the internet(Dlink). Internet goes thru LAN and tunnel that to Dlink and throwing that to a Linksys WAP54G Access Point. And to that broadcast internet and connection to the other unit in two way.
    In its manual driver should be install first before installing the hardware. And goes thru finalization of installing.
    The thing is the tech does not jot down its settings before going to reformat it. LAN settings is easy it is automatically detected. But to the dlink PCI, setting the required parameter to communicate with WAP54g AP is the problem.
    That's why I'm inquiring, I think they just installed the driver since the PCI dlink card is already been seated in the PCI card. Is it not an issue if it is just directly installed the driver negating the manuals recommended process?
  • fougzki May 15, 2009
    I just did a test if it can be done. And yes it can be, but you should still run the process of installing the utility from the cd, wait until it say to reboot then somehow the finalization of installation.
    Negating the standard process of installing will gonna experience sudden hang up or my ps/2 mouse will not run.
    Thanks for the help.
  • 433 Answers
Yes, the manufacturer doesn't really matter as long as they are 802.11g (usually backwards compatible with a and b) so as long as the router and the adapters are installed properly NO problem
Posted on May 14, 2009
  • John Viguers
    John Viguers May 17, 2009
    If you are having difficulties getting everybody to talk to everybody I recommend that you call Verizon or Comcast (your ISP) and have their techs take over your computer and configure your little network, it is amazing when a check mark here or there will save you several hours of searching.
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
OK. I have the Linksys WAP54g and I am trying to link another computer in my home to this one. I have ethernet and 2 wire. It won't connect. Please help me out here. Thanks, Russell
You must be more PRECIS with your question... What I understand is that you want to connect two computers to the WAP54G (wireless Access Point)??? an than you mention wires ??? if it's because the Access Point is set up to bridge with an other wireless network you can not hard wire two computers to the AP (since it has only one port) unless you have a multi port SWITCH staked/connected to the AP, if the AP is set up to broadcast a WIFI connection than you just need to set up the second computer with the same information as the one all ready working (SSID, ENCHRYPTION KEY, etc...) if it's because you are trying to NAT one computer connected to the AP to an other computer through hard wire, than you need a switch and a good understanding of networking to share a single network connection with two computers...
Feb 09, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
How to conect with wireless internet
The Network and Sharing Center in Microsoft* Windows Vista* can be used to set up a secure wireless connection to the Internet.
Note: If an Internet connection is not automatically made by the operating system, you may need to contact your access point (AP), broadband wireless router manufacturer, or Internet Service Provider (ISP).
Set Up a Secure Wireless Connection to the Internet
These steps assume that your network adapter; AP or router; and cable, DSL or another type of modem have already been physically connected and configured. They allow you to create a new connection and configure it accordingly.
Follow these steps to set up a secure wireless connection to the Internet.
Note: If a wireless profile does not exist, you will need to create a secure wireless profile before you can set up a wireless connection to the Internet.
1. Access the Network and Sharing Center.
2. Select Set up a connection or network.
3. Click Connect to the Internet.
4. Click Next.
5. Select Wireless. At this point, if the network(s) that are listed say that the network settings do not match the network requirements, as shown in Figure 1, create a secure wireless profile and then follow the steps again.
6. Select a network and click Connect. If you are not connected to the Internet, you may need to contact your AP/router manufacturer or ISP.
To access the Network and Sharing Center, use one of the following methods:
  • Start » Control Panel » Network and Internet » Network and Sharing Center
  • Start » Network » Network and Sharing Center
  • Right-click the network system tray icon (the icon that displays two computer monitors) » Network and Sharing Center
Jan 21, 2011 | Computers & Internet
I hooked up my D'link to modem and computer and connection is good. But i can't find it when i search on laptop wireless connection. I think you need i driver but i can't find one. Thank You
4. Click Next.
B52Computers
Jan 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Can't get my lap top to connect wirelessly to my router. Model # WRT54G2. The laptop says it is reaquiring the network address, but nothing happens.
4. Click Next.
Jan 10, 2011 | Linksys Wireless-G WRT54G Router
I got this computer for christmas and I cant get it to connect to any wireless wifi system. I dont know what I'm doing wrong. Could you please give me some instructions on how to connect it to a home...
4. Click Next.
B52Computers
Chris Thrash
Jan 10, 2011 | Computers & Internet
Facing problem-(WAP54G)
Try the following steps:
1. Disconnect the WAP54G power adapter.
2. Reinsert the power adapter directly into the wall socket.
3.Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the WAP54G proper operation.Note: Make sure that you are using the power adapter that came with your WAP54G.
4. Plug the power adapter into a different wall socket in another room.
5. Press and hold the reset button for 1 minute. Release the button. Then turn off the WAP54G for another minute. Then turn it back on.
6. If the power light is still red, then you will need to replace the WAP54G.
Dec 21, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
My Linksys Wireless A P only allows one computer to connect
You need to get a router in order to share the Internet connection. The existing Internet connection (from the DSL/cable modem for instance) goes into the WAN port of the router/firewall, then you connect the AP to one of the LAN ports.
Today it is often a better idea to buy a wireless router instead, i.e a router with built-in wireless AP. They are very inexpensive.
May 28, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys WAP54g v3.1.Can't connect more than 1 computer wirelessly
That is normal for you not to be able to get online at the same time, you are using a Wireless access point, you access point does not have a dhcp server to share the internet on both laptops. What you should have put in there is a wireless router, for Linksys the model of a wireless router will be WRT54G or any model as long as it's a router.
Dec 24, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Wireless internet connection
Hi, A couple of things you should check: 1. Has the "wireless internet user" enabled his Internet Sharing? If yes, how has is this user sharing it with you, through an AP/Router? 2. If he is using an AP/Router, are there any security settings enabled such as WEP, WPA, or MAC Filter? If yes, you have to get the security key and enter it into your configuration. 3. Is the DHCP Server in the AP/Router enabled? 4. If yes to #3, have you made your networking "Obtain an IP Address Automatically? 5. If no, you have to get/set the allowed IP address that you can use, Subnet Mask, Default Gateway and DNS Servers; 6. Can you ping the AP/Router or at least the "wireless internet" user IP Address. To ping, Start, Run, type "cmd", type "ping IP add of wireless internet user and/or AP/Router; 7. In your browser, enable Auto detect proxy settings for this connection; Pls post back with: a. How do you connect, a wifi card/USB or built-in? b. What AP/Router are you connecting to? c. What browser are you using, IE, Mozilla, Opera? Hope this be of some help/idea. Good luck and kind regards.
Sep 19, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
198 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
