Toro Power Clear 221 Electric Start 21 2-Cycle Snow Blower Logo
Mickey Fox Posted on Dec 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Torro snowblower won't throw snow. Gets stuck in auger and blades.
It is at least twenty years old. I have put every lubricant on it I can think of from WD40 cooking spray. Is it time to throw it away and buy an new one?
mburke3
Level 2:
Sergeant:
  • Expert 459 Answers
  • Posted on Dec 18, 2013
mburke3
Expert
Level 2:
Sergeant:
Answers
459
Questions
5
Helped
91443
Points
629
Make sure its turning a good speed, check belts
now that you have all that other junk on it it will be hard to do what you should have done. paint those parts. then spray with wax pledge will work. I buy and resell these and it works for me. nny
Fluid levels in gear box
Amber. With machine on level surface,fill gear box with specified gear oil until it starts running out the fill hole on front of gear box.
press the helpful button and follow me on fixya for more tips
Service
Craftsman snowblower auger gearbox lubricant
Sno Thro Engine Oil Gear Case Lube
Auger Gear Oil Sorry to ask again Snowblower Forum Snow Blower Forums
Feb 09, 2016 • Garden
My Husqvarna snowblower is grinding when the auger is engaged and it will not throw snow.
Most snow blowers have "Shear Pins' that connect the blade to its drive shaft. These 'shear' off when hitting rocks or other debris that gets caught in the blade. Check those and by new Shear pins. If it is not that, then you have problems in the gear box, or shifting mechanisms.
Feb 18, 2015 • Garden
1helpful
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
1helpful
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 • Garden
Mtd snow blower quit throwing snow so i checked the belts and i replaced them and still nothing,so i was agusting the auger cable and the cable come off of the handel so i checked the cable and it was fine...
If I was you I would check key way to see if it has sheered off. It is in center of big drive pulley where belt goes on, Just remove nut and slide pulley off to check condition. Best to split snowblower in half. Your snowblower has two main pieces it will be 4 or 6 bolts to separate your machine.
1helpful
I have a Sears snow blower. It is not throwing even a light snow. On engaging auger both sides spin slowly. I observed one side of the auger stops spinning when proceeding into snow pile. What may be the...
many Sears/Craftsman snowblowers have a shear bolt on the auger shaft or one on each side. This bolt is designed to break under a specific amount of force to prevent damage to the gear box or drive assembly if the blades encounter an immovable object or something becomes jammed (even a newspaper buried in the snow can cause this). They likely broke at some point during use in the past and you did not realize this, or they were not properly installed when the blower was new. If you check the auger shaft and find one or 2 holes that look like something should be there, then you found the most likely problem. If you reply with the model I can tell you exactly where to look and the part # or if you realize the bolts are missing you can contact that parts dept at Sears with your model and they can provide replacement bolts. Can be a pain with small things but a lot less expensive than a new gearbox.
How can I keep my 2 stage snowblower in high?
I will assume you are referring to the 2 stages in the front of the machine. The spiral auger rakes are the first stage, they are designed to collect the snow and feed it to the impeller. The impeller is the 2nd stage and is to throw the snow up the chute. The lower rakes in the front do nopt throw snow only collect it.
Jan 09, 2010 • Mtd Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
