Question about Fuji FinePix A340 Digital Camera
Blurred image on screen
The display screen is blurred to a point where the pix is out of focus. Any help?
  • 355 Answers
Hello friend
which model of camera is using...and give the detail of megapixel
Posted on May 14, 2009
  • 1 more comment
  • Rohit  Asthana
    Rohit Asthana May 14, 2009
    i also want to take a look on this page
    www.aguntherphotography.com/tutorials/why-pictures-look-flat-out-of-focus-dull.html
    thanks
  • Rohit  Asthana
    That option isn't available for the nikon cam some manufactureres call it
    live view, sort of like looking through a video camera's viewfinder and
    it is what is going to to get recorded or what the picture is going to
    be. Some point-and-shoot cameras have that but no viewfinder. Digital
    camera owners have expressed a desire to have that option on DSLR's for
    a long time now so camera makers are adding that feature. It comes at a
    higer price now, but soon it will be a standard just like video for
    DSLR's (D-90). The reason it has been tough to add is that it is a real
    power drain on the battery to keep the display on and have the auto
    focus and metering going at the the same time which is what has to
    happen if it is a "live view". You can keep your display (of pictures
    taken on longer from the menu) but that's not really what you are
    after. Hope that helps.
  • Rohit  Asthana
    One more thing to consider, you really don't want to look at the LCD
    screen to take the photo, it's an awkward position that is not very
    stable for taking pictures anyway. You want to hold the camera close to
    your face bracing it with both hands. Holding it out in front of you to
    look at the LCD is risky and at slower speeds or lower light you will
    get blurred shots. You want to get used the the view finder to get the
    info that appears there as well as the focal area. It's the way the
    pros do it. Give it a try.
    hope it will help you
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Success
Jan 13, 2014 | Sanyo Xacti Cameras
Photos are blurred.
Blurred images are caused by several reasons: motion due to camera shake, use of slow shutter speeds and failure of the camera to focus correctly.
Slow shutter speeds
When light is low, wide apertures and slow shutter speeds will be selected automatically by the camera. Most people can't take blur-free, hand-held shots when the shutter speed is under 1/60th of a second.
Cameras that have optical Image Stabilization help but even IS has its limits. Increase room lighting, increase the ISO setting or use a tripod, or use a combination of all three.
Blurred images or misfocus
If an image is blurred due to camera shake, the blur will appear throughout the entire image. If parts of an image are in focus, and others are not, you've misfocused.
Sep 16, 2010 | Cameras
Images are blurred
Blurred images can have different reasons. Greasy lens, camera shake or focus error.
You can clean a greasy lens with a lens-cleaner solution and lens-paper.
Camera shake will (most likely) only occur on images taken without the flash. Most likely there will be a warning on the display if risk of shake. it's a hand with an "!". Focus error will usually also give a warning in the display.
May 09, 2010 | Fuji FinePix S2000hd Digital Camera
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
What is the solution
You are dealing with "depth of field", or simply put (?), the range from near to far of an image that appears in focus. To increase the depth of focus, the camera must be set to a smaller aperture (higher numbered). Using a wider angle lens helps also. Focusing on the mid-point (near to far range) will also increase the apparent focus range. This is one of the most complicated photographic issues, and much has been written about it. Google "depth of field" for about 4 million explanations.
May 26, 2009 | Nikon D60 Digital Camera
Blurred Images with Olympus E520
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Mar 23, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
Fujifine pix A330 produce blurred image on all picture taken
continuous blurred images? or only occasionally (say in low light)?
Mar 30, 2008 | Fuji FinePix A330 Digital Camera
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Fuji FinePix A340 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
