Hooking up in Stereo
I have a Eurorack MX2442A board, a Crown 1000 Power amp for bottom cabs and Crown XTI 200 for top cabs, also DBX 223XL crossover for our band. I'm running in Bridge Mode now but I would like to hook up in stereo, how do I go about doing so? Any help would be appreciated.
  • 32 Answers
You'll need to use one of the four stereo inputs on the mixer and make sure you wire the speakers separately to channels one and two of the amplifiers. Assuming both of your amps are xti series amps, that's all you have to do.
Good Luck,
BB
Posted on May 17, 2009
I use the crown xti 6000 for 2 double 18s pd186 for bass per channel
Send a signal from the mixer to the amp directly, seems as if you have a distorted signal from your crossover
Dec 23, 2013 | Crown XTi 2000 2-Channel Amplifier
Hello, i really don't have a problem i just want to learn how to setup my system the good way. i have a mackie cfx 12 mk ll mixer, a dbx 233 xl crossover, 2 mackie fr 2500 power amps, 2 harbinger HX...
I can't give you much information other than to tell you the idea of adjustable crossovers is to allow adjustments to suit the acoustics of the room or space where they are sited, a function that used to be common but has largely been replaced by the graphic equaliser, popularly used to adjust the sound to suit personal preference but originally was intended to be used with a white or pink noise generator and adjusted to compensate for mechanical and electronic "inefficiencies" of hi-fi systems to produce a pure sound.
The best advice I can offer you is to start hanging with a few hi-fi nuts to learn what you need to know and lots more. Positioning the speakers is very important for a good sound and popular and inexpensive mod is to fit spiked feet to them or lift them clear of the ground on purpose built stands...
Jun 18, 2017 | DBX 223xl Active Crossover (Stereo 2 Way...
Hello i want to know how many speakers can i conecto to my dbx 223xl crossover 3way
The speakers don't connect to the crossover at all. The number of speakers is determined by the amplifier and the impedence rating of the speakers involved. Perhaps you are not asking for the right information? If the above does not help, please update this with a more detailed description of what you need and I'll try to provide that info as well.
Thanks,
Dan
Mar 27, 2011 | DBX 223xl Active Crossover (Stereo 2 Way...
Hello! I have a dbx 223xl, the right channel is good, but the left channel doesn't work, all de cap and electronic component looks fine, nothigh seem burned out, but it's still doesn't work. What can you...
The only way to troubleshoot this effectively is to use an oscilloscope to signal trace. You can't tell much about electronic components unless they have external damage which often doesn't show.
Jan 10, 2011 | DBX 223xl Active Crossover (Stereo 2 Way...
DBX PA+ no settings for Yorkville EF500P and LS801P
yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
May 05, 2010 | DBX DriveRack 480 Processing Unit Home...
How do i connect my pv2600amp to my peavey subs and top speakers, i have the leads but what do i do?
Line outs Left and Right from mixer to power amp Left and Right inputs,
Power amp outs to Subs(if they have passive crossovers built in check specs on subs).
From Subs then to Main spkrs. Make sure power amp is set in stereo mode using this way.
Alternative: You will need at least a 2-way stereo crossover unit inline after mixer and before power amps if the subs don't have a built in passive crossover. Most of them do have passive crossovers in the subs these days. Then separate amps or one channel would drive the subs and the other the main speakers. True stereo would require at least a 2 way crossover and two stereo power amps if hooking them up this way.
There is another option as is common with many sub setups. Send the signal to the mains using L/R outputs from mixer and a separate Mono output to the subs only. Putting only bass/kick and low frequency outputs in this send would help too.
Oct 13, 2009 | Peavey PRO-12 (00497070) Main / Stereo...
Honduras Church Mahanaim
check out the makers web site for all your equipment manuals
when starting up never make loud always check things working ok at low level
Mar 04, 2009 | DBX 1231 Home Equalizer
131 people viewed this question
 Grubhead
Grubhead
