Question about Canon DM-XM2 Mini DV Digital Camcorder
Eject tape camera ask me to take cassette out. this has happenned frequently in a short space of time. i use new tapes panasonic & sony. i have to now carry a back up camera pls email me the solution ph: Ash in South Africa +27315052762 +27839568976
This problem of yours could be caused by dampness or moisture in the camera. Try to keep the camera in a dry area or dry the camera where the mini tape is with a hairdryer at a sloe warm speed.
Posted on Nov 28, 2007
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
Camera will not record when tape is installed. The motor runs a short while then the camera shuts off. Neither will it eject the tape, but the door operates perfectly when there is no tape in the...
Aw, Based of you have said. May be your cassette housing is deformed or dented, if this happen switches fail to do their job due mechanical deformity. I am afraid may be some other mechanical parts is affected that needs special skill to repair. If you have background in repairing, yes you change cassette housing by yourself, just be careful not to damage flexible wires. Good Luck
Mar 10, 2010 | Panasonic AG-456 Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Sony Handycam DCR-TRV19E Pal do not eject tape
I think, your camera requires new DV Mechanism replacement.
May 08, 2008 | Sony Handycam DCR-TRV33 Mini DV Digital...
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Panasonic NV GS 15 deck jammed
Yes i had the same problem ...
1.Put the cassette as far as it allows... and move the cassette left and right slightly twisting , and you will activate the mechanism
2.SOON the mechanism gets fully out immediately!!!! remove the battery
3.CLEAN contacts (I'm looking right now on the internet to find where the hell sensors-contacts are)
4.PREY that it works :-)
Feb 22, 2008 | Panasonic PV-GS2 Mini DV Digital Camcorder
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
Canon DM-XM2 Mini DV Digital Camcorder Logo
104 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
