Question about Gateway FPD1760 17" LCD Monitor
Stripes appear on monitor at bootup
Stripes appear at bootup. One red line at top: A 1/2" wide Gray and white line below that: A yellow line about 3/8" wide below that and then two more 1/2" wide gray and white lines below the yellow. When I bring up MSM the monitor appears normal. What could be the problem.
Merrill
I decided to change the background of my desktop and it works.
Posted on May 15, 2009
Wide gray bar with thin green, yellow, pink and blue stripes appears when tv is on.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 17, 2015 | Televison & Video
Wiring diagram were can i find ?
All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
Blue/white- Amp turn on
White- Left front +
White/black- Left front -
Gray- Right front +
Gray/white- Right front-
Green- Left rear side
Purple- Right rear side.......the black stripes are your negative speaker outputs.
Apr 05, 2010 | Alpine CDM-7833
I am trying to find a Pioneer DEH-P2000 Schematic diagrams.
schematic for what.....All name brand radios have a standardized color codes coming off the harness.
Yellow- Constant
Black- Ground
Red- Switch power
Blue- Antenna
White- Left front +
Gray- Right front +
Feb 24, 2010 | Pioneer DEH-P2000 CD Player
I have 2 whitw stripes about 2inch wide on my
It is probably just a stuck pixel. As long as the stripes are white it can probably be fixed easily. Read the article below and see if it resolves your problem
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Dec 29, 2009 | HP Pavilion dv9000z Notebook
Red stripes on the screen when choosing a 1280 x 1024 resolution and 32-bit color depth.
640 x 480 resolution means that the screen is 640 pixels wide by 480 tall, ... With the exception of one resolution combination (1280 x 1024 uses a ratio of 5:4), ... A black and white monitor uses 1-bit color depth (2 to the power of 1): ... 5 bits for red, and 6 bits for green, giving 32 different intensities for ...
www.thescreamonline.com/technology/.../monitor_res.html
Dec 06, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
LG Flatron L1930B lcd monitor - 3 vert. stripes, center one dead
sounds like the pixel controllers have gone bad or one or more of the color (RGB, RED, GREEN, BLUE) controllers have gone out. this is quite common in lcd monitors/tvs and is usually caused by pressure on the edges of the screen (you grabbed it too tightly when moving the monitor) or just faulty controllers. they are expected to eventually go bad, ask LG for yourself, they will tell you the same thing. If you just bought it, that can be considered a mfr defect that they will replace, IF IT IS IN WARRANTY!!!!! Unfort. there is no fix due to seal that placed on the actual lcd panel inside the plastic casing. Youd spend more money trying to find the part and install it than just buying a new monitor. hate to say it but im an avid gamer and have gone through about 4 lcd monitors in tha past 3 years due to everyday use
Sep 18, 2009 | LG L1930B 19" LCD Monitor
Need to hook up stereo in 91 accord but its just open stereo wire
Below is the wiring setup for your car:
1990-93 Honda Accord Stereo Wiring
Constant 12V+ White/Yellow Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Best of luck,
Greg
Aug 01, 2009 | 1991 Honda Accord
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Connect Digital and Analog cables at the same time.Any use?
does not help. keep dvi connector (white one) on computer and in the back of monitor.
and surely it will not take away those vertical stripes.
those vert stripes... hmm... your monitor might have a problem which you can't fix by your own.
Feb 22, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Gateway FPD1760 17" LCD Monitor Logo
183 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
