Question about Q-Logic QLE4060C-CK Network Adapter
A/C blower not switch speeds
My air conditioning blower went from only working in two setings to now only working in one(highest) what would cause this?
A/C on caravan only works on high
There is a front-rear blower motor relay control that is involved in the circuits. This control module could be the problem. The blowers bypass the resistors to run on high speed.
You may have to get a repair manual with detailed wiring diagrams to trace the circuits.
Aug 16, 2012 | 2002 Dodge Grand Caravan
2004 honda cr-v blower motor does not run
Try going to this site as they have a lot of ideas: http://www.wikihow.com/Diagnose-a-Non-Working-Air-Conditioning-in-a-Car Also there are some videos on YouTube you may want to see: honda crv ac air conditioner blower does not run
I hope that helps you out!
Mar 31, 2017 | 2004 Honda CR-V
The blower motor for the air conditioning doesn't come on. The compressor comes on. I ohmed the blower motor and it was good. I jumped the blower motor and it turned freely. With the control set 1 2 3...
> With the control set 1 2 3 4 it does blow any air,
? does NOT?
A common problem with this control is the failure of a stepped resistor which causes only the highest speed to still function since this bypasses the resistor.
Tracing the leads from the fan speed switch may help locate it.
Sep 04, 2011 | 1997 Honda Accord
My fan blower motor only works on high,They say it maybe the resistor may be bad, where is it ? Thanks, Jim
Hi, the resistor is screwed to the side of the blower housing behind the glove box. See procedure below to replace the resistor. You don't have to complete all steps in the procedure. just work your way to the point that you can unscrew the resistor. Please let me know if you have questions, and thanks for using FixYa.
1990-93 Accord
See Figures 2, 3 and 4
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Remove the glove box.
  3. Remove the glove box frame (lower support)
Fig. Fig. 2: Remove the glove box and frame
  1. If not equipped with air conditioning:
    1. Remove the three screws and remove the heater duct.
    2. Remove the blower mounting nuts. Unplug the wiring from the blower motor, resistor and recirculation control motor, then remove the blower assembly.
  2. If equipped with air conditioning:
    1. Lift the carpet in the passenger compartment. Remove the side cover (kick panel).
    2. Remove the control unit bracket nuts; unplug the five connectors and remove the control unit bracket.
    3. Remove the retaining band, then remove the blower lower covers. Do not break the tabs on the lower covers.
    4. Remove the retaining nuts and remove the blower assembly.
Fig. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully
Apr 04, 2011 | 1993 Honda Accord
Ford fusion 2007, blown blower fuse, replaced fuse, works at highest speed only (highest of 4) the other three setings don't work.
hte blower resistor is shot, near the blower motor, have the blower motor checked my guess is that it requiring too much power to run, hence the blown fuse
May 06, 2010 | 2006 Ford Fusion
Cabin air fan will not turn on
Sounds like a blower motor resistor that is malfunctioning. It will cause the fan motor to only turn on at one speed, and generally it will work on High only. Pretty comon on and older vehicle, and fairly inexpensive.
Dec 11, 2009 | 1994 Suzuki Sidekick
The blower speed switch only works on 5. The
this problem is caused by a defective blower speed control resistor, it is located near the blower motor, very cheap to replace, part is around $35
Oct 26, 2009 | 2002 GMC Envoy
Air conditioning only works on high - 2002 Grand Caravan
If you are looking for the fan blower resistor, it is located behind the glove box. No tools need to get to it and a nut driver to remove the 2 screws to replace it. A 20$ part. It has 2 sets of wires coming off of it. A do it yourself fix.
Dec 29, 2008 | 2002 Dodge Grand Caravan
AIR CONDITION
replace switch, works 9 times out of 9.
Nov 08, 2008 | 1998 Nissan Frontier
Q-Logic QLE4060C-CK Network Adapter Logo
Top Q-Logic Computers & Internet Experts
David Payne
David Payne
Are you a Q-Logic Computer and Internet Expert? Answer questions, earn points and help others
