Question about Canon PIXMA iP1500 InkJet Photo Printer
Dirty print I can print my documents but I have black ink smear marks on the page front and back (not near as bad on the back) . It is not always in the same place. I have done all the cleaning and deep cleaning. I have also done the nozzle check. I also cleaned the bottom plate and roller. The sheets of paper all came out clean.
  • alex18 Nov 25, 2007
    i have done the same types of cleaning and maintenance. Whenever I print a document say in Word, the print is dirty. SOme of my sentences have lines through them and there are black smudges in the margins. Does anyone know who to fix this? Thanks.
    Master:
  • 619 Answers
Hi , clean the absorbent below ,open or any hole can the injection can reach to the use ink basin located in the floor of printer.suck all ink with injection and fill in a clean container.
clean the rubber roller and carriage with the obsorbent cotton or clothe.
Posted on Jan 23, 2008
I have an Epson Stylus DX4850 when i print a document it prints black verticle lines on the back of document.
if you are using a word document to open it on the top select the format tab open it
borders and shadings at the top you wil lsee list of options borders ,page borders and shading across on the left panel select NONE do this for all options
in the preview tab you will see what lines and shadings are on the document
around the edge of the preview panel will be 4 small boxes with lines on the outside of each box make sure none are selected
at the bottom you will see
Apply to with a drop down list with paragraph and a text option make sure paragraph is selected
you can always go back to make sure that NONE is selected
hope this helps
Sep 28, 2011 | Epson Stylus DX4850 All-In-One InkJet...
When we attempt to print it leaves black streak marks. At first it printed all black and when we went to setup under maintainence we chose alignment and clean cartridges. This worked however we still see...
If an inkjet printer gives white streaks where it should be black, it means the ink is very low, or there is dirt under the nozzles preventing it from printing properly, or, in the case of non original cartridges, ink might be leaking which prevents the bubbles of ink to squirt onto the page.
If the streaks are black where it should be white, is sounds like some dust or fluff below the cartridge leaves ink smears on the page.
Aug 23, 2011 | Lexmark X4650 InkJet Printer
Getting black streaks across documents and pictures
Usual cause is defective bllack cartridge or it needs to be removed and excess ink cleaned from the face of it.
SOMETIMES using too heavy of paper can bend up an touch the bottom of the cartridges as tehy move across to page.
Also a paper jam can brush the cartridge and after that the ink is smeared on the cratridge face and will mark the paper as it moves across.
Using BAD refilled cartridges is a common problem.
Nov 08, 2009 | HP Photosmart C6380 All-In-One InkJet...
What happened? Only cyan prints.
Thought--------- Repairs will be more than a new printer. Buy another one.
They are always on SALE.
Good Luck.
Nov 01, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Smeared print on paper
I was getting a similar blur/blob down one side of the paper (with no discernable print anywhere,) but after removing and emptying the toner collection bottle my printing returned to normal. I am still working on the size mismatch issue, which seems to be prevalent in the 2300DL population.
Aug 25, 2009 | Office Equipment & Supplies
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Prints roller smear marks
Laser printers do not use Ink. The problem is most likely a defect on the drum, which in this model printer, is part of the toner cartridge. Replace the black toner cartridge with a known good one and test.
Oct 03, 2008 | Lexmark C752 Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dirty print
Try to print in high quality paper a thick paper
Apr 22, 2008 | HP LaserJet 1150 Printer
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA iP1500 InkJet Photo Printer Logo
175 people viewed this question
old marine
old marine
