Question about LaCie d2 DVD-RW Burner
No installation disc for lacie d2 dvd rw - LaCie d2 DVD-RW Burner
  • 5,660 Answers
You shouldn't need an installation disk, just burner software. May I suggest this free burner software? Infra Recorder. I used to use
Nero, but switched to Infra Recorder, and like it Much better!
1.Info about Infra Recorder on Wikipedia.org,
http://en.wikipedia.org/wiki/Infra_Recorder
2.Infra Recorder homepage,
http://infrarecorder.org/
On this homepage you may want to go to the right, and click on
-> Screenshots, under the Pages heading.
If the Lacie D2 DVD-R/W burner drive is the only optical drive installed, Windows should 'see' it as new hardware. ("Found new
hardware" "Found Lacie D2 DVD-RW")
Be sure the 4-pin Molex power connector, is installed in this optical drive, also the interface cable, and the 4-pin audio cable.
Posted on May 14, 2009
  • joecoolvette
    joecoolvette May 14, 2009
    If you're using a version of Linux like Ubuntu, for an Operating System, this is a whole different ballgame.
Need to re-install drivers for LaCie 2d DVD RW with lightscribe
HI there,Use the page below to get your drivers, download them by saving to your desktop, and then install from the saved file.
http://www.lacie.com/search/index.htm
Regards
Sep 11, 2010 | LaCie d2 DVD-RW Burner
Nec DVD writer. Does not load disc, although it is is trying to. Nero copies and burns DVDs but 1Click, clone DVD, Fab programmes won't. Any ideas?
Used to run into this all of the time.
  1. Nero and Roxio are famous for this. Writers have their own set of drivers that different burning programs hook into to transfer the data onto the disk. It's a hierarchical structure, and quite often a new installation of software takes over those hooks for itself, leaving a disconnect for the other programs.
  • I bet that you either installed or updated Nero most recently.
For the disc that won't load. Is it just one or all? If a disc gets damaged in the base volume files, this can easily happen.
May 30, 2009 | LaCie d2 DVD-RW Burner
Just bought a lacie d2 dvd +/- rw, store bought dvd movies don't mount and therefore don't play
Disconnect the Lacie dvd drive, then reconnect it and open "system profiler" to see if the drive is now recognized under "firewire" or USB depending on your connection. If that doesn't work disconnect all peripherals and turn off your mac for 5 minutes. Start reconnecting your devices one by one.
Dec 16, 2008 | LaCie 16x LightScribe DL DVDRW (LAC300786)...
Lacie external dvd burner not detected
DO YOU HAVE THE DRIVERS FOR THE BURNER CORECTLY INSTALLED ?
TRY IT ON A DIFFERENT COMPUTER TO SEE IF IT WORKS.
IF IT DOESNT YOU MIGHT NEED TO CHANGE EIGHTER THE DRIVE OR THE BURNER
Dec 30, 2007 | LaCie d2 DVD-RW Burner
DVD RW reading problem
Ok it seems as if the drive may be dying or is dead. You said you used these disc before so the problem is with the media(disc) its with the medium*the drive) I dont think flashing the firware in this case will hely you will need to replace the drive :)
Dec 11, 2007 | LaCie d2 DVD-RW Burner
DVD+RW problem
When burning CD/DVD use a lower burning method... as not to rush data to burn and make sure that before burning the let it verify or test the data burned on the CD/DVD... it takes time, but be patient, after all it is your data.
Dec 10, 2007 | LaCie d2 DVD-RW Burner
LaCie d2 DVD-RW Burner Logo
438 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
