Question about Fisher and Paykel GWL11 Top Load Washer
I have a Fisher and Paykel GWL11. When I start a cycle it stops
About half way through the cycle and starts to beep. There is no way to restart the cycle unless I restart the whole cycle by turning off the machine and re-entering the washing cycle that I had choosen. After I do this it will run smoothly through the entire cycle. (It is not unbalanced).
  • holts4 May 15, 2009
    Thanks for getting back to me. The answer to Stephanos 18 is 00110100.
    Hope to hear back from you!
    Thanks Again,
    T
  • 144 Answers
OK If you tell me which lights are flashing when it beeps I'll tell you the fault eg there are eight lights 00000000 1=on 0=Off cheers
Posted on May 15, 2009
  • Steven White
    Steven White May 16, 2009
    Ok this fault code 52 means you most likely have a faulty Diverter valve. Replace this part which you'll find at the bottom of the machine when it's tilted back (It's connected between the three hoses). If you still have the fault after replacing this part then you'd need a new motor controller module also. Cheers
    Problem Solver:
  • 12 Answers
Assuming this unit is out of warranty, possible causes with out an actual view.
Water Pressure switch. If this switch has a leak of any sort may cause your problem, An adjustment in the water level will cause this. Check you unit for leaks. will not be major but enough to change pressure on switch.
If unit is balanced, this is the most likely cause for this error.
Posted on May 14, 2009
Fisher and Paykel GWL11 Top Load Washer starts but drum won't turn, it twitches and beeps then turns off with solid beeps
Hi ken
Can you turn the bowl & agitator by hand.
If it can't turn by hand, Your seal & bearings need replacing.
Feb 01, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Jun 01, 2008 | Fisher and Paykel GWL11 Top Load Washer
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
322 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
