Question about HP OfficeJet 7310 All-In-One InkJet Printer
WANT TO PUT BLUE GREEN PIECE BACKIN TO BE ABLE TO FAX MULTIPLES
PRINTER GOT JAMMED DO i OPENED IT UPTO OUT BLUE THING WITH 14 EDGES ON IT AND DONT KNOW HOW TO GET IT BACK IN
    Sergeant:
    Champion:
  • 240 Answers
Try find the backdoor of that printer and then open it..that will allow you to pick-up the jammed paper easily..^_^
hope this help.
Posted on May 14, 2009
The paper is jammed where you fax something
please conduct the shop kapeer and service of fax
May 08, 2012 | HP Officejet 6500 Wireless All-in-One...
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
Panasonic fax kx-fp153
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Paper jam
alternative :
Mar 23, 2009 | Sharp UX-B20 Plain Paper Inkjet Fax
Whether paper jammed?
give this a try
alternative :
Feb 28, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Brother personal fax190 paper jam
alternative :
Dec 17, 2008 | Brother Personal FAX-190
Jam
alternative :
Oct 28, 2008 | HP 920 Plain Paper Fax
Check document message
you will almost certainly have a torn piece of paper ( or small document) in the document feeder sitting over a sensor.It doesn't need to be very big to be detected.Open ALL covers on the feeder, check particularly at the edges of the feed area where you may have torn a corner off.Sometimes you can hand feed a piece of card through by turning the belt or rollers and push any obstruction out..........
Jul 28, 2008 | Canon imageRUNNER 1023iF Black and White...
Paper Jam
hey, give this a try:
alternative :
Jul 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Installed Lexmark 1240 but when I try to set up fax it says no modem found
Yes, This assumes that you are hooking the printer upto a 56k/Fax modem on the Computer, Which the Printer already has itself, What you will want to do, Is hook a Phone line upto the the Printer in the appropriate slot, and dont worry about setting the Fax feature up on your Computer, Just Worry about the Scanner, printer. For the Fax Feature, Dial the number on the Printer and It should work without Ever touching the Computer
Jul 11, 2008 | Computers & Internet
HP OfficeJet 7310 All-In-One InkJet Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
