Question about Homelite Garden
I need a manual for a homelite gas hedge trimmer HT-19 I need the factory settings for the carb. bottom out screw turn out 1 1/4 turn? Have to hold throttle wide open to run.
  • 246 Answers
Hello cosorio70:
You can Get a Manual from the Following Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information. Remember to have the UT Number if this Unit has One.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
How much oil goes into the fuel of the homelite 240 chainsaw
please check your manual,some are 25:1,40:1 but get the mixture right as you can damage the machine.
Sep 25, 2010 | Homelite Factory Reconditioned 26cc...
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran...
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Aug 06, 2010 | Homelite Factory Reconditioned 26cc...
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
How do i replace the pull cord on the ht-22 homelite gas hedge trimmer.I can not find the manual on line.......
Remove the housing with the coil in it. Remove the screw on it, its the screw with about 3/8 washer on it. It is where the old rope was hooked up, and should still have a piece of it under the washer. It has a D shaped groove under it. take the new rope and burn the frays on it make it stiff and small. Turn the pulley around and around until it gets real tight, and align the hole in the pulley with the hole in the shroud. Take a c clamp or visegrips and clamp it in place if you can. I just hold it, then feed the rope through the hole in the shroud and pulley and rap it round D shape groove. Replace the screw and washer. Tighten it up then let go of pulley. It should zip up real quick and all way to the handle, and be real tight.
May 11, 2010 | Homelite Factory Reconditioned 26cc...
Backwards chainsaw blade
You remove the two nuts that hold the bar on, then the cover will come off. Don't forget to loosen the adjusting screw next to the bar to loosen it. Also, don't forget that once these two nuts are off, the bar will come off as well.
Mar 28, 2010 | Homelite Factory Reconditioned 26cc...
Does anyone know the factory mixture setting screws for electrolux hedge trimmer
Carefully Bottom each screw and turn out 1 to 1 1/2 turns. This should get you started. Adjust low and high speed screws till it idles and does not hesitate on high
Oct 21, 2009 | Electrolux Gas Hedge Trimmer
Oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Garden Logo
1,470 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
