Question about Hitachi 60FX20B 60" Rear Projection Television
Dirty Mirror how do I clean the mirror on my 60FX20B Hitachi
    President:
  • 788 Answers
You must be very careful when cleaning the mirror, it is not like any other mirror as the silver is on the front of the glass. I believe that Hitachi's are made of glass and not mylar.
Do not use a glass cleaner, as they have drying agents in them.
I try to avoid cleaning the mirror unless it is really dirty. It is very easy to leave streaks on the surface.
Most likely you would be well served by using a mild detergent in a bowl of water, a soft cloth, (I like to use cloth baby diapers) anything that is lint free. Do not let the cloth drip into the set.
Clean the surface with the damp cloth and dry with a clean dry cloth.
Try to use the dry cloth to remove any streaks.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for you support and use of FixYa
Posted on May 14, 2009
Hitachi projection tv mirror problems
the mirror in projection tv, needs to be cleaned along with the lenses for each crt clean them both and your tv will look like new good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
Remove tv screen from hitachi projection tv
The entire screen unit can be removed but first remove rear cover and look at the lens--clean with a lens cloth etc----peek up inside and look at the mirror--if not dirty or smudged just clean the lens.
removing the screen with its frame can be tricky--easy to damage the screens etc. Removal usually requires front speaker grill to be removed first---most just pull off but a few are secured from rear by some screws.
With it off look to see if at bottom of screen there are a row of screws--if the entire front unit can be removed it will pull out at bottom and be snapped in place.
A better suggestion is look at rear of set above back cover--if the upper part is plastic--it with the back removed can also be removed--careful as mirror is bolted into it---that way you can clean the mirror and get at the lens for the tubes without trying to remove screen unit--some of the smaller sets this is the ONLY way to get at the mirror.
Yes a number of screws but if plastic upper rear comes out with mirror much easier and safer way.
May 29, 2012 | Televison & Video
I have a hitachi 55vf820 lcd rear projection tv. How do you get the cover off to clean mirror?
Don't try that as the mirror almost never needs cleaning and MUST be cleaned with a special cleaner---leave a single fingerprint on that mirror (or a smudge) and it will stand out in the picture like a sore thumb.
Reason to clean mirror?
Apr 09, 2012 | Televison & Video
I can't find any documentation on how to remove the primary mirror for cleaning. I'm a newb and don't want to mess anything up. Thanks, Bob
First -- how do you know the mirror needs cleaning? Did you shine a flaslight down the tube and see some dust? Never use a flashlight to determine if a mirror is dirty-- they are ALL dirty when you use a flashlight to check them.
Only clean the mirror if it is interferring with the views through the scope.
There is a ring around the back-- remove those screws and the mirror should come out-- don't driop it! Then remove the mirror from the mirror cell.
Sep 03, 2011 | Celestron Advanced C10-NGT (600 x 254mm)...
My tv has been getting darker I"m guessing it the mirror or the bulb is going out
It would most likely be the bulb. however open it up and see if your mirror or bulb are dusty, as this can also cause a decrease in brightness.
Mar 07, 2011 | Hitachi 60FX20B 60" Rear Projection...
I have a Tasco 302911 (Old model) D=114mm F=500mm that has been sitting around in the closet for some time. Has become dirty from sitting around and would like to clean up and adjust as required. Would...
The only thing fragile are the main primary mirror and the smaller secondary mirror anything else can be cleaned with Windex and or Pledge.
To learn how to clean the mirrors read this:
http://www.astro-tom.com/tips_and_advice/cleaning_optics.htm#article1
The mirror should be VERY dirty or leave it alone.
You must do this gently or you will scratch the mirror. Once the mirror is clean you will need to re-collimate the scope. Watch this video:
http://www.andysshotglass.com/Collimating.html:
Aug 03, 2010 | Tasco Galaxsee 46114500 (500 x 114mm)...
CAN I CLEAN THE MIRROR ON MY HTACHI 43FDXOIB TV
With the set unplugged remove the back cover of the set.
Next remove all the screws on the entire large plastic shroud that is black in color; you will notice hand holds to lift it free and the mirror is attached to the inner side.
l usually use paper towels and glass cleaner to clean it and also clean the three large black plastic lens in front of it. It either is dirty or grimy the picture will be affected.
Carefully replace the mirror/shroud unit and put all the screws back that secure it.
Replace the back cover and see what it looks like. There is no access from the front of the set to do this.
SD TECH
May 09, 2010 | Hitachi Televison & Video
Screen is dim and not very bright
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Dec 09, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Smoked out
UNSCREW THE TOP BLACK PLASTIC, IT HOLDS THE MIRROR SO BE CAEFULL WHEN YOU REMOVE IT, FROM THERE IT WILL BE OBVIOUS WHAT TO DO, CLEAN THE MIRROR, BULBS AND BACK OF THE SCREEN. GOOD LUCK
Nov 05, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 60FX20B 60" Rear Projection Television Logo
187 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
