Panasonic RR-US470  Handheld Digital Transcriber / Recorder Logo
Posted on May 14, 2009
I need software for Windows XP for Panasonic RR-US470
I bought the Panasonic RR-US470 but I came to study abroad, bought a new computer with Windows XP but did not bring the CD.
Can someone help me to find a web page where I can download the software?
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on May 14, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
0
Helped
14510
Points
66
The only place you can get it free is from peer to peer file sharing which can lead to viruses and copyright infringement. Otherwise you can buy a download straight from Microsoft's website.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 06, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
18891
Points
10
You can find software for the IC recorders,
Try a google search, I know that I've seen it. Especially the Vista.
Try:
panasonic (model#450)ic recorder download (vista/window xp)
Panasonic RR-US470 driver windows 8
Unfortunately, Panasonic never fully supported the RR-US470 on any 64-bit Windows OS. The RR-US470 recorder came with the Voice Editing Premium version 2.0. There is a Windows 7 update available here: http://av.jpn.support.panasonic.com/support/global/cs/soft/download/ . The documentation for the update is here:
http://av.jpn.support.panasonic.com/support/global/cs/soft/download/voice_editing21.html . This isn't guaranteed to work with Win7 x64. If you have Windows 8, it might work. With Windows 8.1, it may not work. Starting with Windows 8.1, Microsoft started to demand signed drivers and software for the x64 platform. The original software that came with the voice recorder worked with Windows 98 SE, Win2k, and XP 32-bit. See http://av.jpn.support.panasonic.com/support/global/cs/soft/connect/ve_env.html .
I hope this helps. Unfortunately, many USB connected devices are not supported with regularly updated drivers.
If you do not plan to use the transcribing feature of the Voice Editing software, there may be a slower option to transfer the recording to your computer. Connect the recorder's headphone jack to the Line-In port of the computer, using a 3.5 mm (M/M) audio cable. In the Control Panel for Hardware, go to the Sounds section. Find the Manage Audio Devices option and click on it. In the pop-up, go to the Recording tab. Check that the cable is plugged in and set this to the default recording option. (You can sometimes use the front Microphone jack. However, you'll have to make the computer recognize that you are using it as the line-in.) Use a program like Audacity, http://web.audacityteam.org/ , or any other music/audio extraction software. Set the Audio Host to record from the Line-In. Start recording then start the playback of the digital recorder's audio file. Use the computer speakers to listen to the playback. Adjust the volume settings so that the audio recording doesn't go into the red zone (too loud) or too soft. The indicator for too soft is a lack of volume fluctuation on the audio trace. After you finish recording the file, you can export the audio as an MP3 or other audio format.
(I've never used a digital recorder in this way. I have converted audio cassette recordings with the Line-In method.)
4helpful
How to download driver of recorder rr-us470 for Windows XP. I need help urgently. Many thanks
Unfortunately Panasonic aren't all that good at software, you might need to update windows.
I need the PC software for Panasonic recorder (RR-US450) to operate on Windiws 98
I use windows 7 and it does not regnize my recorder when plugged on the USB port of my computer. What do I have to to?
You need to run the software first in compatibility mode, Panasonic aren't good at software updates
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
