Question about Frigidaire FRS26R4A Side by Side Refrigerator
I am trying to test the voltage to my condenser fan. What voltage testing instrument should I use so I don't short out anything?
    President:
  • 2,559 Answers
120vac
A multi meter will work fine,But it is not going to prevent you from shorting something out,Only you can prevent that.
Posted on May 14, 2009
2005 Ford E350 Van Door locks & dome lights are going on & off on there own
Do you know anything about automotive electronic's ? Control modules ?
Vehicle Security Module
The vehicle security module receives inputs from the following:
  • Door ajar switches
  • Keyless entry keypad
  • Ignition switch
  • Remote keyless entry (RKE) transmitter
The vehicle security module uses these inputs to control an output signal to the instrument cluster which controls the battery saver relay and interior lamp relay. The battery saver relay and the interior lamp relay are internal to the instrument cluster, and are not replaceable. There could be a faulty switch input to the I/C - insturment cluster , causing the vehicle security module to activate the lock's an light's .
Interior Lighting Systems
The instrument cluster grounds the battery saver relay and interior lamp relay coils when any door ajar switch is opened, or the interior lamp (headlamp) switch is closed. The interior lamp relay then supplies voltage to the interior lamp circuit. Vehicle speed must be less than 24 km/h (15 mph) for the instrument cluster to ground the interior lamp relay. The interior lamps remain illuminated for up to 25 seconds after all doors are closed unless the instrument cluster receives an input from any of the following:
  • voltage from the ignition switch.
  • a vehicle speed signal.
  • input from the keyless entry keypad through the vehicle security module.
  • input from the RKE transmitter unlock or panic switch through
  • the vehicle security module.
Do you know what DTC'S - diagnostic trouble codes are ?
Could have DTC'S stored in the following Modules
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1320 Driver Door Ajar Circuit Open Instrument Cluster Go To Pinpoint Test C . B1328 Passenger Door Ajar Circuit Open Instrument Cluster Go To Pinpoint Test C . B1342 ECU is Defective Instrument Cluster CLEAR the DTCs. REPEAT the self test. If DTC B1342 is retrieved again, INSTALL a new instrument cluster. REFER to Section 413-01 . All Other DTCs - Instrument Cluster REFER to Section 419-10 .
Vehicle Security Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground Vehicle Security Module Go To Pinpoint Test C . B1330 Passenger Door Ajar Circuit Short to Ground Vehicle Security Module Go To Pinpoint Test C . B1338 Door Ajar RR Circuit Short to Ground Vehicle Security Module Go To Pinpoint Test C . B1342 ECU is Defective Vehicle Security Module CLEAR the DTCs. REPEAT the self test. If DTC B1342 is retrieved again, INSTALL a new vehicle security module. REFER to Section 419-10 . B1574 Door Ajar LR Circuit Short to Ground Vehicle Security Module Go To Pinpoint Test C . All Other DTCs - Vehicle Security Module REFER to Section 419-10 .
Your best bet mite be to take to a qualified repair shop .
Sep 05, 2017 | Ford Cars & Trucks
Fix my instrument cluster
Do you know anything about automotive electrical testing ? Checking power an grounds , loaded circuit voltage testing , voltage drop testing ? First place to start would be to have a factory or professional grade scan tool hooked up , check for DTC'S - diagnostic trouble codes . There are videos on youtube on basic automotive electrical testing , voltage drop testing . Check for resistance , corrosion in wiring connectors an terminals. Lose ground connection's etc....
Oct 15, 2016 | 1999 Pontiac Grand Am
2006 Chevy Silverado 5.3 Code B2610
DTC B2610
Circuit Description
The body control module (BCM) receives a variable voltage signal from the instrument panel (I/P) dimmer switch requesting to illuminate the illumination lamps to a desired intensity. When this occurs, the BCM directly sends a variable voltage based on the I/P dimmer switch position on the instrument panel lamps dimming supply voltage circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuit.
Voltage for the instrument panel lamps dimming supply voltage circuit, instrument panel lamps dimming control circuit, and the LED dimming signal circuits is from the TBC 2 A fuse in the instrument panel fuse block directly through the BCM to these circuits.
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Is the TBC 2 A fuse in the instrument panel fuse block open?
YES - Go to Step 3
NO - Go to Step 4
Test the instrument panel lamps dimming control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 11
NO - Go to Step 8
Test the instrument panel lamps dimming supply voltage circuit and the instrument panel lamps dimming control circuit for an open, high resistance, short to voltage or short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 11
NO - Go to Step 5
Are you confused yet ? The info above is a Chevy factory repair manual diagnostic flow chart for DTC B2610 . Your best bet would be to take your vehicle to a qualified repair shop .
Aug 14, 2016 | Cars & Trucks
I have no fan speed on my auto temp heat or ac
Replace the motor ! Test the electrical circuit ! Don't know anything about automotive electrical circuit ? Go on youtube an check out video on basic electrical trouble shooting , Also Voltage drop testing a circuit . How to read a wiring diagram . Then go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Test the circuit . Do a current draw test on the blower motor . You need a amp meter to do this test .
Dec 15, 2015 | AC Cars & Trucks
Gem module
The GEM has nothing to do with it !
Odometer/Trip Odometer
The odometer and trip odometer are displayed in the integrated circuit LCD display. The instrument cluster records the total mileage of the vehicle using information received from the PCM, and electronically displays this information in the LCD. If this information is not received, the LCD displays all dashes. How did you prove that instrument cluster isn't bad ?
Did you have a factory scan tool hooked up , check for DTC'S - diagnostic trouble code's ? View data to the instrument cluster etc...
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1202 Fuel Sender Circuit Open Instrument cluster Go To Pinpoint Test B . B1204 Fuel Sender Circuit Short to Ground Instrument cluster Go To Pinpoint Test B . B1205 EIC Switch-1 Assembly Circuit Failure Instrument cluster INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation. B1342 Instrument Cluster Is Defective Instrument cluster CLEAR the DTCs. REPEAT the self-test. If DTC B1342 is present, INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation. B1359 Ignition Run/ACC Circuit Failure Instrument cluster Go To Pinpoint Test A . B1317 Battery Voltage High Instrument cluster Go To Pinpoint Test N . B1318 Battery Voltage Low Instrument cluster Go To Pinpoint Test N . U2199 Invalid Data for Engine Coolant Instrument cluster Go To Pinpoint Test D .
Your best bet ,take it to a qualified repair shop.
  • The speedometer/odometer is inoperative
  • Powertrain control module (PCM).
  • Instrument cluster.
  • Go To Pinpoint Test F .
Dec 04, 2017 | 2005 Ford Focus
Short need help 96 toyota camry
Test the relais condenser and replace , and test again if the fuse is blown.
Otherwise you must go to the repair shop.
The short is the most difficult are to isolate.
You will need a VOM.
May 10, 2012 | 1996 Toyota Camry
I seem to have a problem with the power to my computer. After 2 days of searching all kinds of forums I still haven't found a solution. The computer won't power up, no fans are spinning, not a...
First remove the power plug from the smps and press the power switch few time and wait for few minutes the re plug the power connector to the smps and switch on the computer if you still dont have power then you will have to check whether the smps work to test that its not enough to test the voltage in the 21/24 pin you will have to short the green wire and the black wire and see whether the smps fan is working if the fan is not working then the problem is with smps
Jul 30, 2011 | ASUS Computers & Internet
In winter the refrigerator make ice not in summer, just cleaned the evaporator which was totally cove with dust, noticed also that the compressor is hot and all the coopper pipes also are very hot, what...
The reason everything is hot is because you stopped the unit from "Breathing" through the condenser (not evaporator) by allowing dust to build up.
This is how the system disperses heat absorbed in the freezer section (evaporator).
Jun 08, 2011 | GE Monogram Side by Side Refrigerator
Condenser fan motor does not run
You will have to test for voltage at the fans plug.If voltage is present.ensure that earth is ok,if the earth is faulty,earthing will cause fan to work.Also try giving the fan motor a few taps with a hammer,it may start but will need to be replaced.
Some fans have an extra signal wire.test that this is working when air is on and temp is dropped.
A failed fan will cause overheating in the air cond system which will cause the seals to rupture and loss of pressure=no cooling.
I hope this helps,or get back to me with further findings from tests and perhaps vehicle model info.
Mar 25, 2011 | Dodge Ram 1500 Cars & Trucks
Fan will not shut off, but compressor does
hi! there, continous fan motor when unit was shutt off,since supply source was already cut off specially on fan condenser motor,the supply of your motor was came from relay mounted on your circuit board control panel,there a holding coil to hold the connection between your fan and ac source,shut off breaker for ac unit first before diagnosing ac unit, try to check this out the relay is still activated giving ac source when shut off,the contactor on relay holding your ac supply was shorted,try to check the connection the circuit activating condenser fan relay,eliminate the short circuit,using multi tester test rod,use manual diagram for circuit control board to lessen complicated diagnosing,focus on fan relay ac source then isolate checking the short circuit replace defective relay,contact point of relay are not repairable.take necessary precaution on checking to avoid shock,this a hard task i would suggest that certified ac technician w/ full knowledge of instrumentation should do this.thank's for selecting fixya and have a nice day.
Mar 30, 2009 | Intertherm P3RA-036K Air Conditioner
Frigidaire FRS26R4A Side by Side Refrigerator Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
