Question about Gateway M-6834 Notebook
Gateway M-6834 laptop -- power blinks
I have a Gateway M-6834 laptop and when I turn it on, its power button and wireless light blinks (no matter f I turn on or turn off the wireless manually). The fan doesn't work and actually the computer doesn't start. Only these two lights are blinking. I unplugged the battery and only used the adaptor, but again it didn't change and the same happened.I do appreciate your help!
  • mrphoto31 May 19, 2009
    I have the same EXACT problem with my Gateway m6834 laptop. Any help is greatly appreciated!
Im having the same problem. did you find a solution?
Posted on Nov 10, 2009
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
My Gateway M-6847 will not turn on. When I press the power button the wireless light and power button light just flashes quickly. Also the battery light in front stays lit while plugged in.
Hi
silly question sorry
but have you charged the battery or plugged the power cord into plug and switched on to try to charge the battery for a couple of hrs without using the laptop
Jun 23, 2011 | Gateway M-6847 Notebook PC
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Notebook power button is blinking red when I try and turn in on. Plugged into ac adapter
sounds like bad adapter.red blinking light means dead battery.so if charger is bad it will not power the pc or charge it.
Oct 16, 2009 | Gateway M-6834 Notebook
Gateway m-6750 power light and wireless light flashing
Try logging in in safe mode.
Try entering the BIOS and resetting to default values.
Try booting up from your CD drive
Aug 26, 2009 | Gateway M-6750 PC Notebook
Red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Jun 12, 2009 | Gateway M-6834 Notebook
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Gateway m-6834 battery light blinking red and won't turn on
Either:
A) Bad battery
Easy to check, take it out and try to boot. If yes. Get a new battery.
http://www.shopbattery.net/gam6mselirel15.html
If no.
B) Bad AC adapter
Does the power brick have an LED on it? Is it on. Even if it is it may not be putting out voltage. If the cord gets bent alot it can break inside so it looks normal. If you or some you know has a MultiMeter , have them check the voltage.If you know someone with the same laptop, try theirs. If it works get a new one.
http://www.buy.com/retail/product.asp?sku=209143953&listingid=29869055&dcaid=17902
C) Broken connector inside laptop
If a known working AC adapter doesnt work there could be a broken connector inside that needs to be resoldered or the power subsystem on the board could be fried.
Mar 04, 2009 | Gateway M-6834 Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
I have a gateway m-6755 series laptop/notebook power issues
first press & hold power button for 6 second then again press power button to boot...
Dec 01, 2008 | Gateway M-6755 Notebook
Gateway M-6834 Notebook Logo
952 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
