Cars & Trucks Logo
p
paul subat Posted on Dec 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Holden wiring diagrams
Trying to fit 3 wire turbo timer to 05 diesal rodeo not sure which wire to use on the ignition barrel
Grahame Begg
Level 2:
Sergeant:
Champion:
  • Expert 293 Answers
  • Posted on Dec 15, 2013
Grahame  Begg
Expert
Level 2:
Sergeant:
Champion:
Answers
293
Questions
Helped
75283
Points
878
Don't have a wiring diagram but if you use a volt meter find live wire on fuse box, connect this to power wire then 2 wires to fuel stop solenoid, using the wire from the stop solinoid to timer this activates the timer and the other from timer to solenoid. This will allow the engine to start by activating the solinoid, I hope this helps
Merry Christmas
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Sep 12, 2008
SOURCE: 1994 isuzu holden rodeo injection timing adjustment
try u-pull our patrs
Anonymous
  • 87 Answers
  • Posted on Aug 27, 2009
SOURCE: im trying to install a tacho into my 1993 holden
Hi Dano,
For installing the tacho on a vr there should be a single wire not pluged into anything, on your wire loom under the bonet on the LHS, this is the wire you need..
Please let us know if that was helpful enough.
Thanks
Shiv.
Anonymous
  • 1111 Answers
  • Posted on Sep 22, 2009
SOURCE: wkich wire to get a tackomoter signel from the
moz-screenshot.pngmoz-screenshot-1.pngred wire goes to +
Anonymous
  • 6 Answers
  • Posted on Sep 26, 2009
SOURCE: wire colour coding for radio Holden Nova LF
Car Radio Constant 12v+ Wire: Blue/Yellow
Car Radio Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Anonymous
  • 642 Answers
  • Posted on Feb 23, 2012
SOURCE: 02 wireing on ecu 1999 isuzu trooper
D14 and D15 for sensor A and C14 and C15 for sensor B on connector C2 for the 6 cylinder
2answers
2006 Holden / Isuzu Rodeo turbo diesel keeps blowing the ECM fuse?
ISUSU? no
must be 12,000 miles away down under?
a HOLDEN car, you never told makers name,
wrong fuse size, only use correct size.
the ECU can short easy if CAPS inside short and 2006 to 8 was a bad year for caps. called he CAP Plague
so unplug ECU and see if fuse holds
can be bad wiring, harness.
or damage from rodents. ROO'S? LOL
seen vast ecu short me, for sure 1995 to 2010.
caps go bad. electrolytic type. the leak, split open or explode too.
some only short as car hits bumps, never fun this\
hey good luck downunder ! it's 100f here.
Hi I have a 1992 holden rodeo dual cab turbo diesel. 2.8l and manuel I was wondering if the engine components of a 2000 model fits a 1992 model
At www.reliable-store.com get complete guide on whether to repair or not, service it, and how to repair etc, along with wiring diagrams, electrical diagrams, torque specs,
error codes, everything.
1helpful
Hi - looking to fit a Mongoose MAP80 upgrade alarm to a 2011 Colorado dual cab - does anyone have wiring diagram or info for door trigger, arming/lock wire & disarming/unlock wire Thanks
Peter, This is what I found on google search, you can also try google search Mongoose MAP80 upgrade alarm wiring instruction as there is a lot more info. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.mongoose.com.au/vehicle-installation-manuals/MAP80inst.pdf
http://www.mongoose.com.au/vehicle-wiring-holden/colorado_2009_2010.pdf
Engine and transmission wiring diagram isuzu 4jj1
a USA CAR,"??????
be like 50 pages in the book, we can post that
buy a book.?
log in to mitchells, diy (google it) and read. like us.
the wiki shows. (there are not just one jj1,)
The 4JJ1-TC is a DOHC 16 V 3.0 L common rail direct injection engine with turbo and intercooler which replaced the 4JH1 in the Holden Rodeo and later Chevrolet & Holden Colorado produced in Thailand. Stock power was 146 hp (107 kW) and 294 N·m with a 17.5:1 compression ratio. Bore x stroke is 95.4 mm x 104.9 mm.
you really have
USA rodeo?
with this DIESEL?
you posted to the:
1995 Isuzu Rodeo
Do 3.1 liter turbo diesel isuzu engines have a one way valve fitted to their turbo cooling hoses?
Can I fit a 3ltr turbo isuzu engine to my 2000 model holden rodeo it is fitted with a 3.2 ltr V6 at the moment
Don't no what wire is ignition to hook up turbo timer on mitsy
suggest you turn on the igniton key and tough the wires to the block where there is no gas... and the one that sparks will most likely be it. good luck
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
