Question about HP iPAQ hw6515 Pocket PC
Application not supporting
when ever i want to install any software on my pda it shows that there is no application. run the application first then open the file from with in the application.
  • 490 Answers
To install any application u need to attach the phone via cable with ur phone using active sync..then run the application on the pc it will get installed automatically on the pda.
Posted on Oct 19, 2007
Bought TX but have no desktop software cd
Yes if you go to you will find a section for support. You can download everything you need there to get your PDA up and running. Once you have the software installed on your computer you will want to go in and enter all your information like names and addresses in your contact section. Once you have that all done you connect the PDA to the computer by using the usb cord and then hit HotSync. You can go back later and update any of your infomation right in the PDA itself. Best wishes. Let me know if you need any other help with this.
Aug 11, 2009 | Palm TX Handheld
Visor Deluxe does not start
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
on Apr 09, 2010 | Handspring Visor Deluxe Handheld
Application to use RSS Reader .
Try talking to your phone provider they might have the information needed to get it setup for that good luck
Jul 26, 2009 | HP Photosmart C7280 Laser Printer
Provide me a software
You can try this application for your PDA ( It supports synchronization with MS Access but this link is a trial version of the software. I hope this helps.
Apr 18, 2009 | ASUS P525 Smartphone
To install new software
Nowadays PDAs and Smartphones come with different operating systems. Nokia and Sonyericcson use the Symbian based software. You have indicated your model group as i-mate. It comes with Windows CE pocket PC edition which is totally different than Symbian. There are many softwares available. what kind of software do you need? You can proceed to and choose the category as Windows CE or Pocket PC you will see alot of applications
Good Luck
Feb 10, 2008 | i-mate Pocket PC
Lost all contacts, memos, tasks, after LifeDrive Update 1.0
This morning I downloaded LifeDrive Update 1.0, and when I did a HotSync afterwards, I got an error message saying, Handheld Tasks application database version not supported. Handheld Notes application database version not supported. Now my contacts, memos, tasks, calendar entries and possibly other items are all gone!! This is the core data that is the reason why I use a PDA! I would be totally distraught, except that the data does still seem to exist in Outlook on my PC. I am running Outlook 2002, SP3 on a WinXP machine. Can anyone help to fix this problem? thanks,
Sep 12, 2005 | Palm LifeDrive Handheld
Can't see application
Have you every heard of a product called "dotPocket"? This program allows you to change the resolution of your PDA screen even if your PDA doesn't technically support a higher resolution. The screen on my PDA is only 320x240 but with this I can make it 800x600 and anything in between. With it, you can scroll the screen. Use Google to search for it. It comes with a 30 trial but after that you can delete it if you choose not to buy it. Hope this helps some.
Sep 11, 2005 | HP iPAQ RX3715 Pocket PC
Connection problem
Have you considered software running in the background on your computer? Usually firewall/anti-virus software can block the connection. If you are running any Norton or McAfee products, it is likely the cause. Try disabling them, or boot into safe mode with networking support and see if the PDA responds from here. Safe mode loads a minimal set of drivers and no startup programs. Goodluck!
Sep 11, 2005 | HP iPAQ HX2755 Pocket PC
Casio E-15 and Linksys WCF11
Well - if your PDA runs CE 2.11, it should install. Try downloading specific CAB file from Linksys's website for the MIPS processor (E-15 uses VR4111). If you have Linksys WCF11 card, go to If setup still doesn't work - copy a MIPS CAB file to your Casio via ActiveSync and run it from there. However, even after you install it - you might face problems. I still wasn't able to run my Linksys WCF11 on Casio E-100. Apparently, there is no easy way to specify IP settings (gateway, WINS, DNS) in Windows CE 2.11 for Linksys (unlike PocketPC OS, where we have network settings in control panel). I tried playing with registry - however, it messes up big time.
Sep 05, 2005 | Casio Cassiopeia E-15
HP iPAQ hw6515 Pocket PC Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
