Question about Everex StepNote NC1500 Notebook
My everex 1502 wont power up just beeps and goes
My everex 1502 wont power up just 6 beeps and hangs on blk screen ..green lights on ... HELP..NO screen nothing ..wont go to login nothing ..Vampira
    Sniper:
  • 68 Answers
This commonly occour when there are any complaints with the RAM module. try replacing them or unplug it and again reinsert it som times this can also be caused due o loose contact
Posted on May 14, 2009
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
How do I wire a leviton 7299 combo switch. I have power to the box from standard 3 wire cable blk and wht with a grn ground. I then have another cable again blk/wht with a grn ground going to a set of...
Ok this is a GFCI switch receptacle combo. You will connect the incoming cable to the incoming terminals on the Recptacle. White goes to Line (silver) terminal Blk goes to Line (brass) terminal. For the light connect the white to the load terminal (silver) Then take a short black wire and connect from the Load (brass) terminal to one of the switch therminals. Connect the remaining outgoing black wire to the other switch terminal (at bottom of switch) connect both green wires to green ground screw. (best to "pigtail" ground wires so only one wire on terminal. This will give lights GFCI protection also good for hanging lights in a bathroom.
Aug 17, 2010 | Leviton R02-7299-0NW Switch And GFCI...
Problem with an Everex
this is hang-up on your Everex, check how many beeps you hear and we will identify the problem on your Everex 1500. See to it that your hear the Beeps on your Stepnote, good luck!
Jul 22, 2009 | Everex StepNote NC1500 Notebook
EVEREX NC1502 Windows XP drivers
Hi!
Have you tried www.cnet.com this is the site that has never failed me for Drivers, patches and FREE downloads.
Good Luck,
Press the Blue Button please to appraise my FREE! Effort.
Thank You!
Paul 'W' U.K.
Mar 03, 2009 | Everex StepNote NC1500 Notebook
Everex Stepnote NC1500 wont boot
Are there any other lights on or any other activity, or does it just die? If it only pops up with the hard drive light briefly then dies, your laptop might just be dying because the battery isn't holding a charge.
Jan 08, 2009 | Everex StepNote NC1500 Notebook
Don't keep memeory
follow this code:
Black-----------ground
Red------------12V Switched (ignition)
Yellow---------12V (constant)
Blue------------power antenna
Blue/white----Amp turn on
Orange--------dimmer
White----------Left front+
White/blk-----Left Front -
Gray-----------Right Front+
Gray/blk------Right front-
Green---------Left rear+
Green/blk----Left rear-
Purple---------Right rear+
Purple/blk----Right rear -
In a grand-am the radios yellow goes to the cars orange and the radios red goes to the cars yellow.
1998 Pontiac Grand Am Stereo Wiring Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Trigger Pink Antenna Right Rear Front Speakers 4" x 6" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
May 13, 2008 | Alpine CDE-9843 CD Player
No display whatsoever.
it doesnt sound like the moniter if you have tried switching.you might wanna check memory is securely fitted also.
Mar 02, 2008 | Everex StepNote NC1500 Notebook
No Picture on my nec VT676 model
Hi there
I'm shocked that NEC can't answer this guys.
The NEC's & Acer's make use of teh status lights and beeps to warn you that your lamp needs replacement.
Nov 13, 2007 | Office Equipment & Supplies
Everex StepNote NC1500 Notebook Logo
224 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
Martin Murray
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
