Question about Brother IntelliFAX 1270E Plain Paper Fax
The copy/receiving function will not work.
The paper in the paper tray is not pulled in so cannot print incoming faxes or make copies.
  • 30 Answers
Hi,clean feed roll if the feed roll out of use please replace it.
Posted on May 14, 2009
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Disabling the fax function
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Apr 23, 2009 | Gestetner - DSm618d Digital Imaging System...
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
How do I get faxes and copies to print from tray 2?
That is an advanced feature, genrally this is known as Automatic drawer eligibility. However, I am not sure this device offers this advanced feature. Look for options to select drawers for your diff functions in your users manual. Sorry best I can say...
Jan 06, 2009 | Office Equipment & Supplies
Will not make a copy
If it won't copy, it is unlikely to handle faxes either since those functions use the same scanner. If your received faxes are coming out blank, then it is a problem with the ink system; if you can get faxes printed but not copy a document, the scanner may be at fault.
Have someone send you a fax to check this function (printing) and then try sending one back to check the scanner.
If either one fails, then hyou know where the problem lays.
Jul 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Check Rec Paper
First power off the machine. Facing the machine from the front, remove the rear tray extension that holds the paper and "feel your way" down into the right side of the of the back paper tray. You should feel a out-of-round feed roller. With a little effort you can rotate this around. Take a terry like cloth and dampen it with water and clean this roller. Before puttin any paper back into the tray, turn the machine back on so the paper feed assembly will return to the home position.
Jul 15, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Brother IntelliFAX 1270E Plain Paper Fax Logo
98 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
