Question about Sport & Outdoor - Others
We just purchased a used '99 Starcraft Field & Stream PUP. There were no instructions for setting up the awning. I need step-by-step ''how-to'' help since everything I've found says, ''raise support poles and attach cross-support''. This has not helped. Have 12 pieces of poles for assembly; 3 w/plastic nipple, 3 w/plastic hole, 3 w/small rubber end and an elongated metal ring and 3 w/larger rubber end in addition to the metal pole across the front edge of the awning. There are no ''pockets'', hooks, brackets, etc. into which you can place or hook any of these poles or ends except the holes in the metal pole across the front of the awning (one on each end and in the center). pdm21588
I had exact same problem on my 93 popup. I finally figured it out. First, the poles with the plastic rings slide into the poles with the metal rings. These are the vertical support poles. Next, the poles w/ plastic nipples slide into the other poles with rubber ends. When put together the poles with the nipples should be spring loaded. These spring loaded poles rest against the top of the camper and the nipples are inserted into the 3 holes of the pole that go across the front of the awning giving you rafter support. The tension from the spring should keep the pole in place against the side of the camper. The first 3 poles with the plastic rings go from the ground to the front awning pole where the nipples can slide through the plastic ring and then into the awning pole. The vertical poles can be adjusted for height by sliding them up or down and then twisting them like a screw to tighten them up and keep them in place. 2 of my 3 vertical poles will not lock when I twist them so I have to get tricky with them. The metal rings, which should now be at the ground, are there so that you can stake it down under windy conditions. I hope this wasn't too confusing but I beleive it will help you. Good luck!!!
Posted on Jul 21, 2009
Http://www.rv-coach.com/current_category.198/Forum.89114/offset.480/forum_thread_full.html
Try the www above. I have a 1994 Starcraft, bought used and have never tried using the awning until last summer and was stumped by the pieces. I am determined to figure it out this year! Searched the web for some instructions; came across these but have not used them to put up the awning. Hope they work because I'll be trying them too.
Iowa popup camper.
Posted on Jun 10, 2009
The awning manufacturer for rv
You can go to RV awning manufacturers or to marine awning makers. They all use the same material. Also a Chinese company listed below.
  • RV Awnings Online - RV Awnings, Awning Parts and ... www.rvawningsonline.com Representing Carefree RV awnings, parts and accessories for over 10 years. Order online or call 800-780-8677. - Scotties Canvas, in business for over 50 years.
  • Rv Awning Manufacturers, Rv Awning ... - alibaba.com www.alibaba.com > ... > rv awning > rv awning manufacturers Rv Awning Manufacturers, Wholesale Various High Quality Rv Awning Manufacturers Products from Global Rv Awning Manufacturers Suppliers and Rv Awning Manufacturers ...
  • RV Superstore Canada. Awnings & Covers rvsuperstorecanada.ca/awnings-covers Shop by manufacturer. A-1 SECURITY; ADAMS MANUFA; ... Awnings & Covers; Slide Out and Window Covers ... Awning Accessories
  • RV Awnings, Patio Awnings & More - Carefree of Colorado www.carefreeofcolorado.com Carefree of Colorado develops, manufactures, ... Fifth Wheel or Toy Hauler, we have a HUGE selection of awnings and RV accessories to outfit your rig!
  • China Rv Awnings, Rv Awnings Manufacturers, Suppliers ... www.made-in-china.com/.../hot-china-products/Rv_Awnings.html China Rv Awnings - Select high quality Rv Awnings products varied in Style, Operation Method and Frame Material from certified Chinese Pvc Tent factory, Frame Tent ...
  • RV Awning Manufacturer - LoveToKnow camping.lovetoknow.com/RV_Awning_Manufacturer Once you buy your RV awning, the next thing you have to think about is how you are going to install it. While it is possible to attach it yourself, it can be ...
  • China Rv Awning, Rv Awning Manufacturers, Suppliers ' Made ... www.made-in-china.com/products-search/hot-china-products/Rv_Awning... China Rv Awning - Select high quality Rv Awning products varied in Style, Operation Method and Frame Material from certified Chinese Pvc Tent factory, Event Tent ...
  • Luxury RV Awnings - Girard RV Awnings - Girard Systems https://www.girardrv.com All our girard product designs and innovations greatly improve the aesthetics for awnings and ... The reason why more RV manufacturers and RV owners choose Girard ...
  • http://www.bing.com/search?q=rv+awning+manufacturers&qs=SC&pq=rv+awning+manufacturer+&sc=2-23&sp=1&cvid=8F5A4EBCFB8E47908A2DD6EFE172B072&FORM=QBRE
    Jul 10, 2016 | RVs
    I need a new watchband
    So go online, find your nearest Field & Stream dealer and order one of your liking. You need to post on fixya for that??????
    May 30, 2016 | Field and Stream Watches
    The awning has two rollers and is manually operated, but we can't figure out how to use it
    Teresa, I will post links to videos on awning set up and use. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    How to Use the Awning on Your RV
    RV Awning Tutorial
    1 How to Open RV Awning
    How to Use and Maintain Camper Awning Pete RV Service Tips
    May 25, 2016 | Dometic A&E and Carefree 18 Universal RV...
    Does th starcraft star stream ss18rb have a water pump
    If the trailer has a fresh water holding tank it will have a pump. The older units have a hand pump located next to the sink. There should be a switch located inside the camper, typically on the monitor panel. When you turn that switch on and open the faucet you should hear a vibration noise. If the switch does not illuminate that could be that the circuit is dead and the fuses will need to be checked. The pump is usually located near the sink behind an access panel that will be screwed shut.
    May 22, 2014 | Starcraft 2008 Star Stream SS18RB
    Awning toppers sagging and filling with water
    Hi Ced,
    I would syphon out the water and tighten the awning. If the fabric has stretched too much from the sagging, you may need to add a stabilizer or replace it.
    I found a great eHow article that will walk you through the steps for both scenarios: http://www.ehow.com/how_12125906_fix-sagging-awning.html
    Best of Luck!
    Sep 22, 2013 | Dometic Deluxe 120" Slide Topper RV Awning
    Mio pup i have. no instructions were given!
    The instructions for your Mio Pup can be found at the Hasbro Website.
    To find the manual follow this link:
    http://www.hasbro.com/common/instruct/67323.pdf
    Feb 28, 2009 | Hasbro Oye Mio Pup
    Compass dial turned opposite direction
    you might be able to reverse the poles back to normal with a magnet but be careful not to scratch face or get it closer than you need to to the insides of the watch.
    Sep 26, 2008 | Field and Stream F25SLUMI Wrist Watch
    Sport & Outdoor - Others Logo
    940 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
