Question about Lands Phones
I am trying to connect external speakers throught the earphone jack on the side of the Aria 716D handset. I have the step up jack and have connected a set of speakers without much success. Advice will be appreciated
  • trevor_webec May 14, 2009
    I have connected a new set of powered speakers which have an inbuilt amplifier with no success.
    President:
  • 987 Answers
You need to connect a not only speaker but also amplifier ..
Posted on May 14, 2009
  • Sibananda May 14, 2009
    then the port in the phone might have some problem...
Left earphone broken
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPhone with another set of headphones or speakers just to make sure that the problem is with the iPhone.
Bad audio jack
The most likely cause of audio output problems on iPhone 4S is a bad audio-out jack. If you have determined that the problem does not lie in your external speakers, you should replace the headphone jack.
please follow the steps and fix it.
God bless you
May 28, 2013 | Cell Phones
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
No sound but reading discs
Every one enjoys listening to music . When CD player stops doing its job we take it to a repair shop. But before doing that we can try out few simple ways to troubleshooting CD player which may save us from paying huge amount for repair.
Troubleshooting involving diagnosis and then fixing it by finding the cause for the problem. First step involves focusing on a specific problematic area . Next step would be to check if the connections are proper and the last step is to troubleshoot. Let us look at each step in detail..
You can start by checking the earphone port,By using an earphone jack,inserting into the earphone port...If no sound comes out from it, that means it's not from the speaker, but from the board of the radio.The sound IC has is damaged and will need to be replaced..
To fix these,you might need to contact a repair man.
But, if sound comes out from the earphone jack, That means it's a minor case,it will be a problem from the speaker of the Mini Disc Player.
Checking the speaker connection..You might need to open up the speaker
Test the speaker by using a AA battery with small wires on the positive and negative side of the speaker. If sound comes out,that means i wire has cut or remove from somewhere inside the speaker, But if still no sound coming out,That means will go back to IC on the bard of the radio..
Keep me posted when your done checking..
Thanks for using fixya
Aug 07, 2011 | Sony MDS-JE330 Mini Disc Player
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
How can I hook these speakers to a laptop pc? I have a dell inspiron laptop with an output for the earplugs. I was wondering if the ADA995 could be attached to a mocked-up plug for this output. Seems these...
External speakers can be connected to the earphone jack,BUT remember the computer output is only designed to power earphones not big speakers. The speakers have to have an amp built in, like some desktop speakers. Also if you use an adapter to connect the speakers, you MUST make sure the grounds and output wires are matched correctly or you will fry the computers audio board or worse.
Sep 01, 2009 | Altec Lansing ADA995 Speaker
Low and bad quality sound by headphone port
sounds like an internal problem
like a bad connection
if you have the skill, you could pull it apart and resolder the parts around the earphone output jack
hope this helps!
Jun 27, 2009 | iRiver X20 MP3 Player
Very low volume
check the mode button and make sure you are in the right mode, sounds like you have it in the wrong mode.
Sep 16, 2008 | Icom IC-R10 Handheld Scanner
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Lands Phones Logo
49 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
