Question about Whirlpool Duet GHW9150P Front Load Washer
I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
I have a Whrilpool model LHW0050PQ4. I interrupted the start of a cycle and now the lights are flashing continuously and it won't start or lock the door. I have tried unplugging it for hours and it didn't reset the washer.
  • mirelesdesig Jul 08, 2009
    I replaced the main controller and tried the other solution, but the problem persists. :o(
  • Cava Jan 24, 2013
    It know it's too late... I'm posting this for further similar problems: have you tried to open the small door at the bottom, unscrew the pump filter and remove all stuff from the filter?
    Problem Solver:
  • 6 Answers
You need to turn off, unplug, plug back in, turn on, move cycle knob to stop, wait a few minutes, and then select cycle you desire, press start and hold handle firm against door 'till light stops blinking and it should go.
Posted on Jun 22, 2009
  • 51 Answers
UR MAIN CONTROLLER NEEDS REPLACING. IT HAS A COMMUNICATION ERROR
Posted on May 16, 2009
Maytag refrigerator door panel lights are blinking nonstop
You might need to vacum underneath so the coils don't get hot. Or change out the water filter.
Dec 10, 2014 | Refrigerators
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
970 washing
make sure your door is closing good and tight
Mar 08, 2014 | Kenmore Washing Machines
Power went out and dryer is blinking "pf" and no buttons work
It blinks "PF" to indicate that the cycle is interrupted due to a power failure. Press Start to continue the cycle or press Stop/Cancel to clear the display then restart the cycle.
Unplug the dryer for at least 30 minutes to forcibly reset the control if the display does not clear out or if the dryer cannot be restarted. Indicate the complete and exact model number of the dryer for further and specific troubleshooting repair advice.
Aug 22, 2010 | Kenmore Dryers
Start / resume light blinks. dishwasher won't cycle
my dishwasher runs through the cycle as normal for 20mins and then starts bleeping nonstop. opening the door the start light flashes without any pauses and the light above prewash is on. my engineer cnat figure this out as the flashing has no pauses. help.
Jul 02, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Wrench (repair)light is on. It's a Lanier 7313.
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Sep 23, 2009 | Lanier Office Equipment & Supplies
My Kitchenaid dishwasher won't start.
sounds as if your having a problem with the latch assemblt, not recognizing the door is being closed, so its waiting fot he door switch to be activated
Jan 10, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Maytag quiet series model #:MDBH950AWB
The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Whirlpool Duet GHW9150P Front Load Washer Logo
1,346 people viewed this question
Dan Webster
Dan Webster
Sal De
