Question about Brother MFC-7440N Laser Printer
Double sided copying
How to do double sided copying on mfc 7440n
  • 433 Answers
Http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
Posted on May 14, 2009
Brother mfc 7440n - drum stuck in machine
Does the cartridge come out? I would try to turn it on so that the fuser gets hot. It may help losen thngs up. You probable need to replace drum too?
May 25, 2015 | Brother Mfc-7440n...
How do I print double sided without scanning
You specify double sided from the print menu. For example from a Word file rather than just clicking the print icon; click file, print, select the appropriate printer, then properties. From there you can detail paper, paper source, 2-sided print, etc.
Oct 15, 2014 | Brother MFC-7440N All-In-One Laser Printer
My brother mfc 7440N prints splotches every 3-3.5" on every page printed. This occurred with the previous and new toner cartridges. How to fix?
For crying out loud.
The "blotch" is caused by damage to the drum or to the toner fusing roller.
If the "blotch" is loose toner (in other words you can smear it) then the fuser roller is damaged and that assembly needs to be replaced.
If the "blotch" is fused (in other words you cannot smear it around) then the drum is damaged and that assembly needs to be replaced.
The original MSRP for the Brother MFC-7440n in 2008 was $429 (US) / 213 pounds [FixYa couldn't handle the pound sign!! =8-) ] (UK) / $499 (AU). The present street value is about $199 according to Brother ( http://www.brother-usa.com/MFC/ModelCompare/4/MFC7440N_MFC7460DN#.UXBKKKLq3yA ).
A drum unit is $80 (Amazon) or $115 (Staples).
That same $200 could get you a Canon Pixma MX-922 (Canon http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx922). Inkjet? Yes. But fast. Airprint. 2-sided ADF and copying. Auto-duplexing. CD/DVD disc printing. Frankly, if I didn't already have an Epson 835, I would buy this one. My old Canon 820 still chugs along as beautifully as the day I got it (about a zillion years ago).
For $50 more you can get a top-rated laser, their imageCLASS MF4880dw (though oddly, without Airprint - for Airprint in a Canon laser, you have to step up to the big boy: the imageCLASS MF8580Cdw).
Well. Have fun!
Mar 31, 2013 | Brother MFC-7440N Laser Printer
I replaced my brother MFC - 7440N with a new cartridge and still has the sign that says toner life end. How will i fix this?
Check the toner cartridge, side gears, you can see a reset lever (that lever is very important) show in the next picture.(cartridge new)
Jun 28, 2011 | Brother MFC-7440N Laser Printer
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
May 20, 2010 | Brother MFC-7440N Laser Printer
Toner cartridge problem
When you remove the drum & toner unit from the machine, there is a small round window where a beam beams through the toner. block it with a piece of paper. Put them back and print again.
Dec 08, 2009 | Brother MFC-7440N Laser Printer
Brother mfc 7440n printer/fax running very slow
Depending on how many copies you have it might be time for a new drum unit. Also, you can change the settings for the resolution for copies in the main menu. Check Menu--Copy--Quality and make sure it is not set on Photo. This would definitely **** up toner as it would print at the highest resolution rather than the default resolution.
Oct 06, 2009 | Brother MFC-7440N Laser Printer
Black line on copies produced
Take a look at your drum. If there's a green tab on the exterior, move that all the way to the left. That should get rid of the black line.
Jul 16, 2009 | Brother MFC-7440N Laser Printer
Need to intall printer into computer
you may download the drivers here on this link,
http://members.driverguide.com/index.php?action=dosearch&qm0=Brother+MFC-7440N+Laser+Printer+&qa5=15&qa6=181&dp=3&sm=b&jmd=and&si=3edccdfe38fe3957f3bf2d496521f422&st=1241757214&gqm0=Brother+MFC-7440N+Laser+Printer+Plotter+Multi-Office
main website is driverguide.com
you only need to register then you can download after that...
May 08, 2009 | Brother MFC-7440N Laser Printer
Brother MFC-7440N Laser Printer Logo
891 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
