Showing and ignition failure code, replaced the ignitor and it lit and went back out three times. Now it is doing the same thing
SOURCE: have to replace ignitor on coleman furnace every year
The voltage regulator on the control module is sending the wrong voltage to the ignitor or the ignitor is getting wet from condensation. That ignitor should last many years. Replace the control module.
SOURCE: goodman gmpn100-4 ignitor lights, burners don't ignite
1 blink is ignition failure
without being able to do voltage checks
i would reccomend checking your igniotor, if you can put an amp meter on it, it should read 2.6-3.4 amps
if you cannot do that, Or check voltages I woudl repalce the igniotor, gas valves do go bad but very few and far between....
at the risk of a bad rating you deserve at least an answer...
if i were called to your house with this complaint I woul not bother comming with out the ignitor
just because the igniotr looks likes its hot,, it may not be hot enough to safely open the gas valve
SOURCE: my furnace tries three times then red light blinks once
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Your furnace has a diagnostic chart on the reverse of the lower panel incorporated in the wiring diagram. One blink tells you that it is a failure but wont tell you where to start looking.
SOURCE: Coleman Mobile Home Furnace - Error Code Flashing Two Times
i have a blinking code 4 times what could it be?
