Question about GE CG505 VHS-C Analog Camcorder
Have a 1995 ge camcorder cg505,looking for cassette adaptor vca115a or 221338. where can i find this. jim.
Found the part i was looking for at EBAY.
thanks.
jim.
Posted on May 14, 2009
My vhs c adaptor wont play my casette. It plays for two seconds then the power to the vcr turns off. Yes I have tried several vcrs
This is because something is jamming either in the adaptor mechanism (nightmare devices at best!) or in the tape cassette.
If you can afford to, escape from this dinosaur technology and enjoy a digital camcorder with a hard drive and/or recording on cards.
No moving parts! No tape tangles, jams or breaks! HD quality!
Well worth considering.
Sep 21, 2011 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
I have a jvc compact aamcoder GR-ax 200 i am look for thepart that you put the tape in and insert in in you vcr.
http://www.amazon.com/Maxell-290060-Mechanical-VHS-C-Adapter/dp/B00012F6A6
Go to the above link to find this part from Amazon.com, it is also available at Wal-Mart, Best Buy, Radio Shack or other online vendors. Cost should not be more than $15. It is called a VHS-C adaptor cassette.
May 04, 2011 | JVC GR-AX230 Camcorder
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
How do you insert a video 8 cassette into the vhs cassette adaptor.
There's no way! They are two vastly different systems.
Video8 tape is nearly 1/4 inch wide whereas VHS tape is 1/2 inch wide - and thats just the begining!
Electronically, everything about them is different which is why Video8 came out from Sony in 1985 to improve on VHS systems and camcorder quality.
The higher quality version Hi8 followed in 1990 which made it's way into the professional market too.
I used the both formats for TV news and other programmes 1989-2000 when I went over to DVCAM, a professional compact cassette system also from Sony so I know the 8mm systems inside out.
Nov 20, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
My sony trv37 cassette door won't close.
If this condition only occurs with as cassette inserted to load this may indicate a condition where the cylinder which holds the video heads is not spinning up when requested by the system control microprocessor.
If the door will not latch closed with/or without a cassette inserted this can indicated a mis-timed condition of the tape loading mechanism.
Try closing the door without a cassette loaded whilst the unit is powered from its AC Adaptor - under certain conditions this may allow the mechanism to reset and may allow the door to then close.
I trust that this information is of assistance! RHN
Jan 02, 2010 | Sony Handycam CCD-TRV37 Camcorder
I cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Jan 01, 2010 | Panasonic NV-GS55 Mini DV Digital...
Sony Camcorder tape P590HGD
YOu may be confusing HI8 with 8mm. One being analog,the other being digital, and a slight difference in form factor
Oct 20, 2007 | Sony P6-120MP 8mm Tape
Video Cameras Logo
124 people viewed this question
Top GE Video Cameras Experts
Are you a GE Video Camera Expert? Answer questions, earn points and help others
