Question about HP PSC 1315 All-In-One InkJet Printer
No power to my HP pcs 1315 all in one
At first it was saying paper jam, then it would say check tri color cartridge cause the carriage was not going back and forth, it was like something was jammed in there. I took off the top, detacged the wire plug ins, and a little white piece of plastic that was shaped like a wheel with a peg through the middle of it. Like it as for somekind of wheel mechansm. I need to know where that goes and how to restore power to my printer/scanner.
Can anyone help me?
Sincerely desperate
Sammy
    Scholar:
  • 121 Answers
Open the rear dooe of the printer...this is a clipon back...remover the back pane and try to view the rollers there ..it looks loike its 1 of these rollers u are talkin bout....insert the roller in the missin slot....reinstall the panel...you should be gud to go
keep me posted...
and ya if this did fix your issue please dnt forget to vote
Posted on May 14, 2009
How do i clear a carriage jame an ,sg find nothing wrong
Click the link below to go to the hp printer support page for your printer paper jam. Pay special attention to the rear door , as many people miss that detail when clearing paper jams.Also , you can click on the troubleshooting link at the top of that page, followed by "solve a problem " in the drop down box to get answers for other problems,
Clear carriage jam and press OK to continue Error Message Appears for HP...
Feb 14, 2015 | HP OfficeJet 7310 All-In-One InkJet...
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
May 24, 2011 | HP PSC 2355 All-In-One InkJet Printer
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 25, 2010 | Office Equipment & Supplies
Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
My hp 1040 constantly jams have tried to clean it and makes little or no difference any suggestions. It will print half of a page then it will say that it is jamed.
>first try to power reset the fax machine, then see if the error still persist..to to a power reset unplug power cord from the back and wall outlet then wait 30 sec and then plug it back
>if the error still persist open the the rear access door and check the if there is any jammed paper in there.using a lint free cloth lightly moistened with distilled water wipe the rollers clean. also check if there is a paper jam from the inside of the printer by opening the cartridge access door
>If there is no paper jam and it gives you a paper jam error message then try to check if the carriage can move freely, first while the printer is on open the cartridge access door of printer cover, the carriage will move to the center which will give you access on it, now unplug power cord from the back of printer with out pressing the power button off. try to check if there is any debris or paper that is blocking the carriage path. with your fingers try also to move the carriage from left to right and see if it can move freely. if the carriage can not move then you have a carriage jam which causes also the paper to jam, if it can move freely then try printing and see if it will jam again.
>also try to remove and reseat the ink cartridge.
>if this will not resolve the issue try a hardware reset, while the fax is on unplug the power cord from the back with out turning it off. press and hold # and 6 at the same time.while holding the buttons plug back the power cord and wait till you see semi-full or nvn reset when it turns back on then release the buttons. if the machine will not automatically power back on press the power button. it should ask for you to select language, region etc a proof that you have successfully done the reset..try printing...
>if it jams again contact hp and ask for replacement if it is still in warranty if its not ask for an upgrade
Sep 21, 2009 | HP 1040 Plain Paper Inkjet Fax
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Feb 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
82 people viewed this question
Seeker5211
Seeker5211
