Question about Jenn-Air JED8430 Electric Cooktop
Stove top will not heat oil hot enough to fry foods. Burner continues to re-cycle on and off while switch is on high. Burner gets red hot for a few seconds then turns off for a few seconds, then back on.
    President:
  • 1,865 Answers
You may have a cracked element, they expand when heated and cause a separation in the element. You really have to put a voltmeter on it to test it under load. If the voltage remains constant while the element is heating and cooling, then indeed you have a bad element.
If you don't have a voltmeter, or don't want to perform this test, buy a heating element and replace it, if you have the same problem, you'll have a spare element
Posted on May 14, 2009
Top main burner want turn off
Switch is either bad in it or has food/grease build up not letting it shut off.
Unless its a newer model and is push button?
Nov 12, 2014 | Frigidaire Stove/Oven/Range Glass Main Top...
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
Wiring Wrong
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Jan 11, 2009 | Cooktops
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
GE Spectra electric burner always on high
Sounds to me like the RF switch is bad.
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Burner gets hot even when not turned on
sound like you have a shorted element, it will stay hot but not high heat hot (glowing) red, other posibility is bad infinate control switch that switch could be bad
Apr 13, 2008 | Cooktops
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
521 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
