Question about SanDisk Sansa e200 MP3 Player
System Locks Up?
When pluged into a usb, of any sort apparently, the system just freezes and I too just had it given to me by a friend whos had it for a while and doesnt know where the book is.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Re: System Locks Up?
Plug the mp3 player back in if there isn't any songs on or your not fussed if you loose the data which is on it go to "My Computer" look for the mp3 player prefrably called "Removable device" or something like that once you've found it make sure it's the mp3 player then right click on it and click "Format".
This to me just sounds like a bug. Once you've formatted try to do player updates which may remove this bug and stop from happening again.
Good luck. Hope my solution helped.
Posted on Oct 24, 2007
0 characters
3 Points
Arch 504 i change hard drive
You can´t swap the internal hard drive if your current firmware is superior to v1.4.0, because system locks it during bootloading (system reads hard drive ID).
May 11, 2010 | Archos 504 500870 Digital Media Player
I just got it from a friend and i dont know how to charge it i know thats kinda funny but what do i do?
it charges from the usb port on your computer, apparently the usb cable and the headphone jack are in the same spot, so listening while charging is impossible,.
Mar 03, 2010 | Trekstor i.Beat MP3 Player
When i disconnected my samsung yp-q2 mp3 it freezes
im getting the same problem as crashes after i reset it and when i want to go on a particular track it would freeze...i have given up with it...gonna try and delete everything from it and try to completely restart it if i can
Feb 25, 2010 | MP3 & Digital Media Players
T.sonic 610 V3.4 1GB Ipod the appropriate firmware from here and hold reset button for 2 seconds the firmware updater and hold "play" button while connecting to system. 5.the updater will detect the player and it will upgrade the firmware.
Aug 06, 2009 | Transcend T.sonic 610 MP3 Player
I have a Centon 1Gmp3 player, have used it for one year. when I turn it on it reads "MP3 player" and does not go to my songs as it used to. it freezes and I have to take out the battery and put it back in...
which operaion system do you use?
win2000, xp, vista or such?
does PC supprt usb 2.0 ?
do you use an apple-macintosh?
(tjing s are different here!)
the PC-based Operation systems should recognize it at least as an usb-stick/removable memory storage item
if not :
- log on as administrator
settings(menu) - then : hard ware/ or system,
look for new devices, wait for feed-back:
- if recognized now, fine ! and handle stick as if it was a disk drive, format it with settings given(all music on it is gone then),
copy the files (mp3's only!), remove and test it!
or :
- if is there is driver problem, whatsoever, take down the possible error code
and come back
Jan 04, 2009 | Centon Electronics 1GBMP3-001 MP3 Player
Deleted files...
All you have to do is right click and "undo delete" Unless you already disconnected the MP3 player and/or restarted the computer. If your critical files were deleted (like the ones that run the player) then go to and select your operating system and it will install them
Jul 14, 2008 | Sony NW-E505 MP3 Player
System files missing in H10 6gb
try 2 plug it in mac operating system mabe u will find something if not ty this trick by pluging it in a play station 2 usb enabled and try formating...
May 15, 2008 | iRiver H10 MP3 Player
I haven't experienced the problem but I've heard of it. Try replacing the batteries. That's what one of my friends did. Sorry if it dosn't work. My friends aren't very good with MP3s. All of them already broke at least one. Hope it works
Jan 02, 2007 | Samsung YP-T7X MP3 Player
Stuck on read system files
i think your hard drive is dead. im not an expert but the same thing happened to me and i got it sorted with a new hard drive.
Dec 17, 2006 | iRiver iHP-140 MP3 Player
My mp3 player wont turn on.
hiya I have a sony bean too and it does exactly the same thing as yours, if you havent sorted it out yet all you have to do is look under the usb flap and you will see a reset button, push it gentally with a pin, it will work agauin and you wont loose all your music, hope this helps
Jul 29, 2006 | Sony Bean MP3 Player
SanDisk Sansa e200 MP3 Player Logo
67 people viewed this question
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
