Question about Philips DVDR3440H DVD Recorder/HDD Recorder
DVD RW stucked - stall the whole system.
I put a DVD RW DISK and it stall in the HDD recorder, all comands are blocked, cannot eject the DVD. I unplugged the thing so it can shut down and tried again to eject the damn DVD, impossible, vicious circle because the system is trying to read the DVD before aboeying to eject it and got stalled anyway...
  • Roxanne2 Nov 21, 2007
    I have the same DVD Recorder, and although I can record to the hard drive, and view what I have recorded, I cannot eject the disk from the drawer, I get a message on the display saying BLOCKED. I have tried unplugging the machine from the mains, and restarting it the next day, but there is no change, the draw will not open. I've only had the machine a few months but cannot take it back to the store because I have lost the receipt, and I really can't remember if I bought the machine from Curry's or Dixon's. Can anyone resolve this problem? I feel like throwing it through the window.
    Roxanne2
  • Leslie Bruce
    Leslie Bruce Jul 02, 2008
    I have a disc stuck in a phillips hdrw 720 dvd recorder. I can hear it spinning but it tries to read and then it shuts off . i have tried unplugging and i have tried turning it on holding down stop and eject. any other suggestions?
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Posted on Apr 01, 2008
I encountered this problem with on a DVR 3460H. After much panic I tried various key options on power on. What worked for me was:
Plug out the unit
Turn it on while holding down stop and eject on the recorder.
It will after about 20 seconds spit out the offending DVD
Posted on Dec 08, 2007
I also managed to fix this issue with the Philips DVR 3460H using solution of manually opening the DVD disc. To do this (1) open the DVDR box by removing the 3 screws at the back and the 2 pairs at the sides. (2) once open remove the metal plate bridged over the front end of the DVD disc - see photos (3) one the plate is removed, on the left side corner there is a white plastic lever and below it a white plastic dial, lift the lever and then turn the plastic dial to open the DVD disc manually. Once open and the disc is removed simple manually close and then replace the plate, close the box and plug it in.
Posted on Aug 30, 2008
Hi all.
I tried the stop & eject on my 3460h but didnt work. However the manual option cured it. It must be a dodgy disc as i tried to play it again but the same happened again. Scrapped the disc.
Posted on Apr 06, 2008
When I insert a blank DVD+R to copy a VHS, It reads the disk, says "Unknown Disk" and ejects it. How do I record if I can't keep a disk in the machine?
some discs don't work in some recorders. I always use verbatim, ritek or tdk discs and have very few problems. if the recorder suddenly dislikes a batch of one brand, I'll use one of the others.
Jan 29, 2015 | GoVideo VR3930 DVD Player/VCR
LG RH265 does not read DVDs
Purchase a DVD cleaning kit and follow the instructions, this will remove any dirt from the laser pickup lens, and hopefully get it up and running. If this fails, the only other option is have the whole laser assembly replaced, "expensive" or replace the entire unit.
Mar 06, 2012 | LG RH1999H DVD Recorder/HDD Recorder
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Sony DVD RW DRU-820A
did you try to do the emergency eject ?
jewellers driver in drive pinhole.
use the eject method again, Computer powered Off. Open the drawer and push it back in firmly.
This is an eject button, make/break switch problem.
Also try ejecting the drive from my computer/Right click with mouse ( CD Drive ) Eject.
And ensure the 4 Pin Molex ( Red-Black-Black-Yellow ) is the right way round. Yellow usually faces to the outside of the casing.
Mike @ compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Will not record says disk error i have aq new disk in
install disk to record from dvd to hdd using dvd-rw dvd- dvd+ disk not een accepted cannot record from hdd.
May 24, 2008 | Televison & Video
Finalizes When You Eject a DVD-R
THIS IS ONE SORRY PIECE OF A DVD EQUIPMENT--BEEN USING LITE-ON & POLAROID DVD/HDD RECORDERS FOR THE PAST 3 YRS W/ GOOD RESULTS--THE SSVR-357 WORKS HALF-*** W/ DVD+R/RW`S
-R/RW`S ARE USELESS--THOUGHT SAMSUNG WAS AN INNOVATOR IN THIS FIELD, BUT NO WAY--
-PIECE-O-JUNK--RUDYB
May 18, 2008 | Samsung DVD-VR357
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Philips DVDR3440H DVD Recorder/HDD Recorder Logo
978 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
