Question about Clarion XMD3
Clarion XMD3 dimmer, how to get it to work?
In the set-up there is a dimmer function that can be set to "on" or "off". I assumed there would be an input to connect to the lights for a signal to dim the lights. I cannot find any such wire.. How does the dimmer work?
  • tgrfan May 15, 2009
    I'm sorry. I don't think I was very clear on exactly what my problem is. The Clarion XMD3 has a "dimmer" function and I assumed it was a feature that would allow me to dim the display at night. I turned the feature "on" but there must be some way to trigger the display to dim. Traditionally it is an input wire to the receiver that is connected to the running lights. I don't see a dimmer input wire on the back of the receiver. How else would the dimmer feature work? Or is it referring to a totally different feature? Thanks..
  • 23 Answers
Early dimmer switches had a pretty straightforward solution to adjusting light levels -- a variable resistor. An ordinary resistor is a piece of material that doesn't conduct electrical current well -- it offers a lot of resistance to moving electrical charge. A variable resistor consists of a piece of resistive material, a stationary contact arm and a moving contact arm.
A modern dimmer switch "chops up" the sine wave. It automatically shuts the light bulb circuit off every time the current reverses direction -- that is, whenever there is zero voltage running through the circuit. This happens twice per cycle, or 120 times a second. It turns the light circuit back on when the voltage climbs back up to a certain level.
-->CAPTION
Posted on May 14, 2009
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Bass and Treble controls
Use Z-enhancer to select custom (you may have to hold it down for 2 secs)
A-M button then selects or bass treble settings.
volume up/down changes the setting
May 19, 2010 | Clarion XMD3
Clarion XMD3 Condensate Problem
the only way to remove moisture is to get it looked at by a local repair shop .Or remove radio yourself ..let it dry for a few days and see if it helped .Water in LCD may not dry completely and may rust LCD with in time
Aug 05, 2009 | Clarion XMD3
Clarion XMD3
This is typically the output IC not working. This can be due to a speaker short. The unit will need to be repaired or replaced.
Jul 05, 2009 | Clarion XMD3
I have a Clarion installed in my boat. Sirrius, cd am fm. No jack to plug in iPod. Solution?
FM Modulator.
(clarion makes a hardwire direct connect one)
FM200
You would use a 3.5mm to RCA adapter
There are also battery powerd ones (Belkin)
Either one is used by simply tuning in to an empty (white noise) radio station.
Im assuming the XMD3-RET is not the radio you are inquiring about since you described Sirius as a feature.
Some clarion radios have an AUX input or changer port that can be converted to an ipod cable.
If you reply with a model # i can look it up for you. I am a Clarion Dealer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question
Apr 14, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Instaling a Clarion XMD3
clarion website download + print
Jan 08, 2009 | Clarion XMD3
Connecting my ipod to xmd3
I believe that if you use the RCA connectors, you can use your iPod. If you use the clarion cca connector, you get more functionality from the dash of the clarion.
Jul 07, 2008 | Clarion XMD3
Clarion XMD3 Logo
280 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
