Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
13.5 briggs runs rough spits & sputters
Spits gas out of carb when running
13.5 BriggsandStratton ohv replaced push rod set rocker gaps ok now I do not have spark.
Posted on Mar 19, 2010
  • 246 Answers
Hello rbryan492:
From your Description it Sounds like a Blown Head Gasket between the Push Tube Galley and the Cylinder, the Valve Clearance Requires Setting or the Flywheel Key is Damaged and Requires Replacing.
>>If you Require More Assistance, then
>>Send me the Model and Type or Spec Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. Many horizontal shaft, overhead valve engines have these numbers stamped into the OHV rocker cover. However, on certain overhead valve powered generators, the equipment manufacturer installs a decorative chrome rocker cover OVER the Briggs cover. If your engine has a decorative cover, it may be necessary to remove it in order to locate the Model, Type, and Code. If this is a Briggs and Stratton Engine, then you can Also Use this Site Addy; http://www.briggsandstratton.com/maint_repair/BS_modeltypecode.pdf for Assistance in Locating the Model, Type and Code Numbers of the Engine.
Thanks.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
17.5hp OHV Briggs & Stratton w/ Nikki Carb sputters & backfires thru carb & muffler
Hi, run a number drill through the main jet. Even though you have carby cleaned it a thin layer of residue will remain on the walls of the jet. The problem you have is a lean misfire. Regards Phil.
Jun 11, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
2004 grand cherokee 4.0l one day it will run fine the next day it runs rough rich and when i step on the gas the engine cuts out and spits and sputters
When the "spits and sputters" happen are you in low rpm? Can you "by-pass" the sputtering by accelerating? Has your gas mileage suffered?
Nov 27, 2011 | Jeep Grand Cherokee Cars & Trucks
Briggs & Stratton Vertical OHV Engine 18 hp blowing white smoke engine run great but a lot of smoke and also have oil being spit out of the black hose that come from engine to the carb.
Check your oil.
If it is overfilled, milky, or smells like gas. Your going to need to change that ASAP. It sounds like the float has stuck in the past or is still sticking, and it has flooded the crankcase with gas, which has mixed with the oil. And because it is overfilled it comes through the breather hose into the carb. This also explains the smoke most probably because the oil is spewing in the carb through the breather and being burned.
Jul 05, 2011 | Briggs & Stratton Briggs Stratton Intek V...
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder...
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
May 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Leaking gas frm bottom and does not run right
the float may b sticking...depending on what type of carb ur running...the spit and sputter problem sounds like you are running a keean carb and if thats the case...there is a extra setting on those that is leaded in from the factory that your average joe doesnt know about...have someone familiar with this adjust it for you and that will help some ...however if itis a keean either live with it or change carbs...that spit you described is just how they operate
Aug 12, 2009 | Harley Davidson FLHTC Electra Glide...
My B & S fouls plugs, runs rough, almost stalls when blade
THE PROBLEM SOUNDS LIKE THE CARB IS RUNNING TO RICH OR TO MUCH GAS IS BEING PUMPED INTO THE CYLINDER. IS THERE ANY SMOKE AND WHAT COLOR SMOKE
Jul 11, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
1,247 people viewed this question
Top Parks Optical Garden Experts
colesmowers
Renee Knafel-Bullock
Adam Jasar
Level 1 Expert
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
