Question about Toshiba 1360 Black and White Copier
No image I just had my toshiba 1360 in the shop for having no image. The tech changed the charging wires and some other parts. It worked fine until the machine started getting hot and then after a few copies once again the image went blank. I checked my charger a to make sure it was in place and it was fine. The light on the top was not flashing when the image went across. Can you please help me? It is going back in the shop in the morning, but I am a teacher who uses this machine everyday. I need help.
    President:
  • 1,126 Answers
I agree with Joey_2. The part number is : 4402-858420 Description : WH-EXPO-121
Posted on Sep 14, 2009
    Problem Solver:
  • 7 Answers
You have the same problem as the other guy it is the lamp wire on these machines if the lamp doesnt turn on the copys come out white seems like you have over 100k copies on it they are very good machines I sold many of them
Posted on Aug 25, 2009
  • 30 Answers
Hi,easy clean optics section that include mirrors.if the mirrors full of dust there is the poblem.
try the first then another solution check scanner section or replace.
Posted on May 14, 2009
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: no image on my toshiba 1360 copier
I would call the service company and explain that my copier was just there and now it is not working...... It is called a RECALL
I have a Toshiba 1360 copier. Went to use it
sounds like one of the charge corona wires broken or the hvt board blown
Jun 11, 2010 | Toshiba Office Equipment & Supplies
Double image
If you go into the customer menu and Select convergence and blue is skewed and will not adjust you have a convergence circuit problem.
Most of these Toshiba sets use two of the STK-392-110 convergence IC chips. Both chips along with any of the 1.8 ohm protect resistors around them that are bad (easy to check--like checking a fuse) need to be replaced and the set adjusted via remote control.
If you can do this yourself you can save a lot of money as most shops are going to charge 300 or more for this type of repair. You can buy a pair of the chips on Ebay for under 15 dollars plus shipping. Total parts cost for the repair should be under 30 dollars.
Both chips have 18 pins and are soldered in. The hard part of this repair is getting at them. If you think you or someone you know can solder and get at them I will be happy to give you general directions and answer any questions you have.
If you get a tech---some are going to say it has to go to the shop---keep looking as any good tech can do this in your home in about 1 hour----I know as I have done hundreds of them here.
If this information helped you rate this solution as I do this here for free.
SD TECH
Nov 25, 2009 | Toshiba 55H70 55" Rear Projection...
Blanc copie toshiba 1360
Hello sir; Check the charge corona wire, see does it broken, it located above the drum unit with blue tab.
Oct 11, 2009 | Toshiba 1360 Black and White Copier
TOSHIBA 1360 copier
.send me your mail
i'll send em for you
rupestha@gmail.com
Jun 29, 2009 | Toshiba 1360 Black and White Copier
No image on my toshiba 1360 copier
May 14, 2009 | Toshiba Office Equipment & Supplies
Toshiba 1360 no image charge wires have been change. what do i do next?
Exposure lamp Cable,or transfer corona.Is the expo lamp lighting??? if no there is posible three options
-exposure lamp cable
-exposure lamp
-thermo fuse
May 14, 2009 | Toshiba 1360 Black and White Copier
Toshiba
Check the corona wires.
Jul 26, 2008 | Toshiba 1360 Black and White Copier
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
135 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
