Question about Toro Lawn Mower With Toro Power Tools
Have wheel horse riding lawnmower that will not engage the blades
I can push the handle up to put the blades in the "on" position but the blades still will not engage. What should I do?
  • amyd_035 May 14, 2009
    The belt is not broken and it didn't look to stretched out but I will check the pulley. I did not hear any squealing nor did it stall. When you press the handle in and looking under neath the movements all look to be working properly however there is a piece that connects to the motor i believe this might be my problem. Do you have any ideas what that could be.
  • jose A. Rodriguez Sep 02, 2012
    Have you checked the spring from your handle to your belt drives?
    President:
  • 957 Answers
Take a look underneath, either the belt has stretched too much and its too long now or it has broke or fallen off. It could be that one of the pulleys have become frozen but you should hear squealing or the engine might stall. Good luck.
Posted on May 14, 2009
Blade will not disengage on Craftsman GCV160 lawn mower.
that type mower the blade always turns when running .
May 07, 2015 | Craftsman Garden
How do I adjust brake/clutch start on troy bilt 42in riding lawnmower
Sounds like a safety switch is not working right. Mine won't start unless I pull back on the handle that engages the blades. If I make sure that handle is pulled up as far as it will go it starts. I disconnected the safety for the seat because when I turned my body the seat moved and shut the unit off and its a new machine.
Sep 25, 2014 | Garden
How do I engage cutting blades on poulan riding mower
There should be a lever on the dash. Push it forward to engage the blades.
May 02, 2014 | Poulan PO14542LT 14.5 HP 42 in. Lawnmower
Lawnmower wheels won't drive
If its a riding mower it probably the drive belts off track or slung off. The mower will still start up and turn blades with the drive belt off, but want engage to go forward or reverse if this is the problem.
Aug 17, 2013 | Garden
Change blade on gas lawnmower
varies slightly as u didnt give model, i run front wheels onto car ramps and block rear wheels, then in middle of blade is a large bolt hold blade with leather glove and unscrew, put new one on and tighten,
Jun 09, 2012 | Craftsman Garden
Serviced my riding lawnmower runs great. but when I put in drive it dies out. Also when I engage blades it dies out. No problems last summer. It won,t stay running when I do these two steps
Probably the seat safety switch. If it's not activated (from your weight on the seat) the engine is killed when you put it in gear, or engage the blades. Lift up the seat and check the switch - wires on tight? switch tightly mounted? You can take the switch out and tape it in the pushed-in position to test things. If that doesn't let the mower run, the switch itself is probably bad, but it could also be a connector that knocked loose when you serviced the mower. Check wires and connectors. Good luck!
Jun 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Jun 02, 2010 | Garden
I have a Troy Bilt riding lawnmower(Big Red Horse) 23hp, when I engage the blades it draws the amps down below 12, and continually draws it down until the blades shut down. I have replaced the battery. It...
I'm guessing the blades operate from an electric clutch and you have a short related to the clutch. Check your switch, wiring and clutch for bare wires shorting to ground.
Jan 07, 2018 | Garden
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
42 deck craftsman riding mower. how do you get blades off? md 91721880.
On most riding lawnmowers, you can remove the blades reaching underneath the deck while the deck is set to its highest position. This may not be possible on lawnmowers with three blades; however, most 42 inch mowers have two blades.
The blades are usually held on with either one or two bolts (on each blade). Oftentimes, too, there is a lock washer underneath the bolt.
If you have auto ramps, it might help to push the front end of the mower up on the ramps. This can give you more room to access the blade bolts.
If the blades have not been removed before, those bolts can be on really tight. You might need to use some kind of breaker bar on your wrench to give you more leverage.
Oct 12, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Lawn Mower With Toro Power Tools Logo
750 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
