Question about Plumbing
Pump humming noise, wont turn
Pump wont turn on and humming noise when switch is turned on..tried a different power cord directly to it same problem..impeller seized ??...help??...
  • Anonymous Mar 28, 2014
    pump hums when plugged in but impeller won't turn unless it's nudged
  • 77 Answers
Yes you are correct...impeller is seized.
Posted on May 14, 2009
I have an in ground fibreglass saltwater pool and the water will filter will not pump.
a humming noise is a frequency noise meaning the motor is not running
check / replace the start/run capacitor for the pump motor
call an electrician for a proper diagnosis
Dec 28, 2016 | Pool & Spa
My 2001 chevy malibu had been working fine up until this afternoon it turns but wont start,itmakes ahumming noise even when i turnoff key.
That humming noise may be your fuel pump burning out. Try turning the key to the on position while someone else listens near the gas tank. The humming should only hum for a few seconds so you won't have time to listen yourself unless you can hear it from inside. If the hum continues and doesnt shut off, it is likely a bad fuel pump. It is normal to hear a small hum for a couple of seconds , but when it starts getting weak, it will hum louder, longer, or not at all
May 11, 2015 | 2001 Chevrolet Malibu
Where is the reset button for fuel pump c
I think the reset switch is in the rear quarter panel. Open the rear hatch and remove the passenger panel. I am not positive on this it could be on the other side. But on the 1990's vintage it was on the right. This switch is used for "roll overs" to shut of the fuel. You might have a bad pump or clogged filter instead.
Jul 30, 2014 | 2000 GMC Jimmy
Why does my hayward power flo matrix makes load humming noise
if humms and wont start turn off then turn backshaft of motor then try if still does that replace motor or pump
Jun 25, 2014 | Pool & Spa
Kracher power washer won't turn on
Sure that the outlet you are using is powered? Is power reaching the motor? - I had my power switch on my karcher break internally rendering machine dead. If power is reaching the motor for sure and it does not run then there has to be an open motor winding. If pump jammed you would hear a humming noise from motor and the breaker would pop.
Aug 26, 2017 | Washing Machines
It makes a humming sound but does not pump water. the pump gets very hot there is no debre in the outflow
The motor is binding that's the humming noise. Check to see what **** the thing sucked up. Then try to clean it out. I dont know what happened
Dec 25, 2010 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Breaker kicks off as soon as switch is turned on
the gfci is defective from moisture even after they dry they can be defective,access the cord inside the machine and try a different cord and see if this is your problem,otherwise the pump motor could be bad,the bypass valve on the pump could be bad,if you could run it you could check current draw with an amprobe,but not if it wont start
Apr 06, 2010 | Karcher K2.26 Electric Power Washer
Sub has started humming with amp turned off. just turned on at wall switch.nothing running
If the hum is from the back of the unit around the amplifier, it may be the transformer. It could be that the mounting is loose.
It could also be that the transformer is going out.
Disconnect all the inputs to the unit, Still hum?
If the hum stops you have something causing noise to the input.
If you have it on a switched circuit, try moving the power plug to a different outlet that is not on a switch. If hum stops, then you have something on that circuit causing the problem
if all inputs are disconnected and it still humms good chance it is the transformer.
Nov 12, 2009 | Velodyne CHT-8 Subwoofer
Karcher hds 501c motor wont turn
never try to turn it on unless you squeese the trigger at the same tme it cant activate the pressure bypass unless it is running you will get ahumming noise and if you leave it on like that you will burn the motor out try that first if still no good come back to me
Aug 09, 2009 | Garden
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Plumbing Logo
442 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
