Question about Microlife Premium Automatic Blood Pressure Monitor
Letters ca come on when unit is turned on also will not shut of with switch
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Cannot log in or turn off tablet to reboot. Touch screen not working.
You should be able to press and hold the power on switch for several seconds and get the tablet to shut down. If it won't shut down with the power switch, leave it on until it shuts off due to low battery and then recharge and try rebooting the device. If it won't reboot after that, check your manual for the factory reset process. See if you can contact customer support for your unit and get the process for re-flashing the bios from them. That usually requires loading a specific set of files onto the external memory SD card and holding down a switch when restarting the tablet. All files and downloaded apps will be erased if you have to go that way.
Apr 25, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
Restart ss-2250 strawberry shortcake dvd player after prog. scan snafu
You should be able to simply shut the unit off, & turn it back on after a few minutes. This will reboot the player & it should perform normally. If this fails, look for a tiny reset switch somewhere on the unit. It will be marked, but may be a tiny hole with very small lettering, that requires a pencil point to activate.
Jul 09, 2007 | Spectra Strawberry Shortcake DVD Player
How can I check kill switches/relays on a craftsman 17.5 Kohler riding mower
get and ohm meter and see if you got voltage coming in on the b pin and when you turn the key on see if you hae the voltage coming from the pin that is marked with a s,
if you disconnect the switch you'll see on the pin's letter's
there should be a B,L,S,G,etc.
Oct 06, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My Hitachi air con (heat/cool) unit is PC-P1H is showing the message H.01 05 and it says the word
Switch it all off. Switch on the outside unit then the inside unit and reset the clock and temperature settings
May 17, 2012 | Hitachi Heating & Cooling
Washer flashing letter
The error indicates that there is no water detected entering machine or Pressure switch trip not detected..If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • 3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Thank you !!
May 31, 2010 | Whirlpool LHW0050PQ Front Load Washer
When I turn the key to shut the engine down it
I don't think the starter solenoid is involved here. T
There should be a fuel shut off solenoid on the bottom of the carburetor which shuts off fuel when the ignition is turned off -- this is a safety feature as well as protection from damaging backfiring.
This fuel shut off solenoid could be stuck open.
There is a switch under the seat which opens and closes the solenoid depending on whether the seat is occupied. This switch as well as the ignition switch control the solenoid.
May 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kenmore stove surface unit light stays on
When the indicator light does not shut off when the burners are turned to the off position, this indicates one of the infinites switches are shorted. If comfortable with electricity, unplug the unit and remove the rear cover exposing the infinite (burner) switches. Using a bright flashlight, shine directly on one of the switches and you will see the following markings. L1 - L2 - H1 - H2, and then the Letter P. This letter P is for the pilot light. Since there is no way of determining which switch is shorted, remove the wire from the letter P on one switch. Isolate the wire removed so it is not touching anything. Place a piece of black electrical tape around the end to be safe. Next, plug it back in. If the light is still lit, move on to the next one until you have found the switch that once the wire is removed, the light does not light anymore. Replace that infinite/burner switcha nd all is well. If I can help further, I am here.
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Kitchen Ranges
CA question
Check the battery. You may need to replace it. What does the manual say?
Nov 14, 2008 | Homedics Deluxe Automatic Blood Pressure...
Microlife Premium Automatic Blood Pressure Monitor Logo
65 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Steve
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
