Question about Yamaha RX-V800 Receiver
No more audio output
I believe that one of the speaker cables + and -  came loose from a speaker and shorted together. What should I look for to fix the problem that I now have?
  • 236 Answers
Did you find the problem with your system? still need help?
Posted on Mar 19, 2008
How to connect tv, direct tv box, and home theater together properly ?
Hi Vincent
That would be a heap of detail to go into. Time consuming...
Hopefully this quick pointer might help.
What is HDMI
High Definition MultiMedia Interface
Note the word MultiMedia
This Means....Both HD Video & Sound through the one cable.
HDMI is the latest state of the art connection.
Use this wherever possible. It's made for High Definition
More Convenient
Use a HDMI cable from one device to the other wherever both devices have that port type (connector).
You don't have to pay a premium ridiculous price for HDMI Cables as in the Monster type. Overpriced.
Well made regular brand & Gold pins are nice. Keep them Short.
Long Cables loose quality. 1 Meter is default.
Your LCD TV should have more than one HDMI port for inputting & outputting media (sound & video)
HDMI can be used for INPUT or OUTPUT
Eg OUT to an Amplifier or IN from a device like DVD Player.
On the OLDer equipment you will Have a YELLOW connector. That is used for the Video signal.
Fiber OPTIC cables are a better way to transfer AUDIO than the red & white cables. Cleaner.
But this only works if the 2 devices have an optical port available.
Some New Amplifiers are smart and may require you to select the optical port in the settings instead of the default HDMI.
This may also apply to HDMI Port Choice.
Simply plug the HDMI in first & check.
Use a known source e.g. play a DVD or CD or Radio Reveiver as a signal.
ONE HDMI Port on the TV might be an OUTPUT ONLY channel (PORT) to an External Amplifier (if you wish to use one)
HDMI on external devices will be Outputing video & sound on their HDMI Port
To the INPUT HDMI PORTS on the TV.
Some TV's will fall back to a particular HDMI port on power fail or startup therefore not requiring you to use the remote every time.
External SPEAKERS should have the polarity checked. Eg Red (or marked wire) to the same post on either speaker. This makes sure that the speakers travel forward together at the same time. Pumping sound forward then retracting together....
so they are not fighting against each other.
.......This is called out of phase & distorts sound.
Hope this Helps
Enjoy Your New Entertainment
Was this Helpful
.......Then give me a tick of approval for my trouble....
HDMI Wikipedia the free encyclopedia
Feb 13, 2016 | Orion LCD TV SLED2480 Sansui - 24"...
How to hook up a Onkyo DV-CP500 5 DVD/CD to a Onkyo AV receiver HT-R500 and a Hitchi 43FDX15BV2G005104 HDTV?
From what I find on the internet, the Receiver and the DVD player do not have any HDMI connections. Therefore, I'm using the S-Video connections. The best way to hook these components up is the following.
DVD player - Use an S-Video Cable on the OUTPUT and connect this to the S-Video Input on the Reciever. Also, connect the two audiot OUTPUTS (red/white) on the DVD player to the RECIEVER's two audio INPUTS (red/white)
RECEIVER - Use an S-Video Cable and connect to the S-VIDEO MONITOR OUTPUT and this will connect to the TV's S-VIDEO.
Speakers will connect to the Left Right Front Speaker, Left Right Rear Speakers, and Center Channel. The sub woofer needs to be connected to the Sub woofer/PreOut terminal on the Receiver.
Oct 23, 2014 | Audio Players & Recorders
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
My technics receiver stop playing, and display an overload message. what do you believe the is the problem ?
If you are getting an overload problem, it indicates an output load issue. Turn receiver off! remove speaker wires from the back of the unit, this will reset the protection circuit. Now power up and turn your volume right down, If the word overload stays off it means there is a short in the wire or speaker. But! if the word overload comes on "even with the wires and speakers dis-connected" it indicates a short in one or more of the audio output ic's or transistors.
Mar 17, 2011 | Technics Audio Players & Recorders
The code E.03 or means that the speaker cable is shorted, or that the speaker cable output is in contact with the vehicle ground. You may need to get a new speaker cable. First check the output for the speaker cable and make sure that it is not touching the ground wire output. If you are sure it is free of contact, the cable is probably shorted.
Mar 05, 2011 | Kenwood Excelon KAC-X811D Car Audio...
RCA RT2770 home theather has no audio output except on sub woofer.
please check first that headphone plug not inserted-set your system and confirm that all speakers are on.
check all speaker cables are not shorted together anywhere.try to test your system when you connect your speaker one by one.
Jul 07, 2008 | Audio Players & Recorders
Display read protected and wont do anything
Usually, protect mode is enabled when the speaker output wiring has shorted together or is touching ground/+12V. I would verify that none of the speaker wiring has come loose.
Mar 19, 2008 | Kenwood KDC-MP5032 - Car Audio CD MP3...
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
LED Light green but no sound.
disconnect all power cables first then short between G&P G&R try again with only one speaker at a time.
Aug 21, 2007 | Alpine MRV-T707 Car Audio Amplifier
Yamaha RX-V800 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
