Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Do not understand how to connect ethernet cable to computer
Cannnot find where to plug in ethernet cable
  • 33 Answers
Plug into where, Your computer? If its a old computer it may not have an ethernet port, If your wondering about the router On the back there should be 5-6 slots 4 close together and 1 on the side maybe circled in a yellow colour, plug it in there.
Posted on Jun 04, 2009
I dont know where the end of the blue cord goes
Hi !
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Thanks.
Mongkey
"Understanding explains better..."
Jan 21, 2011 | Linksys WRT160N Wireless Router
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
No ethernet connection on my computer thats hooked up directly to the 2wire router. how do i acquire ethernet connection?
My guess is that the 2wire router has a DTE plug and a DCE plug. The DTE plug is meant to plug in to your DSL modem, while the other plugs are meant to plug into computers.
If you move the plug, it might work, assuming you have an upstream and downstream connection on the router.
Failing that:
Make sure the cable is an ethernet cable and not a phone cable,
Make sure the wires are run straight through. If it is a crossover cable, it might be meant to connect a DTE to a DTE without a hub, and it won't connect a computer to a router port.
Try a different cable.
Try a different computer (borrow one, etc.)
Jan 18, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a laptop that as access to the 2Wire router but cannot access the internet. The three other computers on the network have internet access. I changed the computer name and that did not work. I...
I dont understand "2 wire router" ... do you mean you have two cat 5 cables plugged into your router? You only have a 2 port router?
The name of your computer is of no consequence in this regard. Pleae check the cable before yo go much further.
XP is normally very good at connecting ...
I recommend Network Magic to solve all kinds of network issues, including connectivity, security and sharing. Get free eval copy by searching Network Magic.
Dec 30, 2009 | 2wire (1000-400108-001) Router
Cannot connect laptop with the eithernet cord
If you cannot connect your laptop using an Ethernet cable, make sure the laptop's wireless ethernet is disabled. To disable it in window xp, click the Start button and open the Control Panel. Double-click Network Connections. Right-click Wireless Network Connection and select Disable from the drop-down list.
04e3ee0.png If you are using a laptop with Windows Vista, click the Start Button and type Network and Sharing into the Start Search box. Select Network and Sharing Center from the Programs list. Select Manage Network Connections from the left pane of the window. The Network Connections window will open. Click on Wireless Network Connection. Select Disable this Network Device at the top of the window.
9a7c8c6.png Troubleshoot the Network
After disabling the laptop's wireless connection, be sure to restart the computer before trying to connect with the Ethernet cable again. If you still cannot connect the laptop to the network with an Ethernet cable after rebooting, check to make sure there is not a problem with the network itself. If there are others nearby connected to the same network, such as in your office, dorm or another public location, ask them whether they are currently able to connect to the network. If no one else is using the network, contact the system administrator or your Internet service provider to see if there may be an outage. This step can save you plenty of time troubleshooting if there is an outage in your area!
Troubleshoot the Ethernet Cable
If there is no problem with the network itself, the reason that you cannot connect the laptop may be the ethernet cable. Make sure that the Ethernet Cable is securely connected to both the laptop and the wall outlet. If possible, try connecting the Ethernet cable into another wall jack or port on the router, and then try using a different Ethernet cable. The Ethernet cable you are using may be damaged.
8686681.png Troubleshoot Network Settings
If the Ethernet cable does not seem to be the reason why you cannot connect to the network, check the laptop's network settings. In Windows XP, open the Control Panel and select Network Connections. Open Local Area Connection and check the status of the connection.
In Windows Vista, go to the Network and Sharing Center and select Diagnose and Repair from the left pane and wait for the results.
If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
If it says that the network adapter is unplugged and you have ruled out a problem with the Ethernet cable and port, the laptop's network adapter may have failed. Try using the same Ethernet cable on another computer. If you are able to connect to the network on another computer using the same Ethernet cord, contact the laptop's manufacturer, a computer repair technician or replace the network adapter yourself.
fc4831a.png If the Local Area Connection is listed as Disabled, right-click it and choose Enable.
Oct 28, 2009 | HP Pavilion dv6000z Notebook
I am connecting 4 nodes through 2 switch located at 400ft distance. the data transfer is not working. 2 nodes are connected to each switch, both nodes connected to individual switch communicates with each...
Just to clarify, you have 4 computers connected to two ethernet switches. Two computers are connecteh to each ethernet switch and a network cable connecting the two ethernet switches 400ft apart.
For all the computers to communicate with each other, they all need to be in the same workgroup "name".
The cable joining the two ethernet switches need to be connected to the RJ45 UPLINK port on both the ethernet switches, and the uplink port may have a switch (the switch allows it to function as a standard RJ45 port or a RJ45 uplink port).
If there is no RJ45 uplink ports on the ethernet switches then a cross over network cable is needed to connect the ethernet switches together.
Oct 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
My XP computer is a wired connection to the modem. The XP computer is supposed to be a wireless connection to the modem. That said, why is it that when setting up the router, I am instructed to plug in...
It's not really required to plug in your PC via ethernet cable to the wireless router in order for you to configure it. It is however, recommended to connect it via ethernet cable initially so that when you changethe wireless settings on the router you wont get disconnected. Please note, that when you connect your PC wirelessly all wireless settings should match (Wireless Name/SSID, Wireless Security (WEP/WPA keys or passphrase), Wireless MAC Filtering).
Jul 14, 2009 | Linksys WRT54G2 Wireless Router
Cant connect my G5 to the Router to get internet
two things to consider. There are two different types of Ethernet cables out there. Perhaps you have a one way cable for the second one. To test this, unhook the working cable from the mac that gets internet and then hook that one up to the one that doesn't get it. See if it sees the network after a minute. The other issue might be in the Operating System. You might need to make sure that they are both up to date with all of the latest updates installed. (I know, hard to do with out an internet hook up.)
Lastly, make sure you are plugging in the cable to the right place on the back of the router. Seems silly, but some of the best have accidentally put it into a link plug to connect several routers rather than an actual Ethernet plug.
Dec 22, 2008 | Apple iMac G5 Desktop
Ethernet cable does not fit into computer
You might be trying to plug the ethernet cable into the modem. This is smaller than the ethernet connectionbut looks the same. If there is no ethernet connection on the computer you might need to have a NIC card install.
Jun 08, 2008 | Computers & Internet
Ethernet vs. usb
FYI for those people trying to use a ethernet and usb cable from a cable modem - it may work for a while but it won't work forever - your ISP will only allow one IP address out of the modem unless you pay for additional addresses (then you need a switch). Each device you have on the modem is fighting for that IP and eventually it will just quit working (if it works at all).
If you want more than one computer on your network (on the Internet or sharing printers/files, etc) then you need a router or a gateway (cable modem/router combo which I DON'T recommend).
Feb 09, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
253 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
