Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Red Lamp I was watching my 65" Mitsubishi 1080p DLP and all was good. I turned it off for about a half hour and when I returned to watch a game something was wrong. When I turn it on, I get a black screen with sound for about 1 to 2 mintues then the tv shuts off and a red "lamp" light comes on. I tried a system reset but got the same result. This unit was not cheap and I have only had it for 11 months. Any suggestions?
  • 4 more comments
  • Anonymous Nov 10, 2007
    Same exact problem here too.
  • Anonymous Jan 29, 2008
    Bought this model less than 2 years ago. It is not working cause the lamp burned out. There is a steady red light in front. Read the manual and the problem is the lamp. If you spend 2k on a tv you should expect it to last at least 5 years if you just use it 2 hrs a day. I recommend that Mitsubishi should not be manufacturing this kind of TV cause it will just destroy there name. I have a friend who has to replace his lamp 2 times in one year. I do not recommend this model to anybody or any model using projection lamp.
  • purple11 Oct 01, 2008
    My tv remains dark and sound until 1 to 2 minutes later it turns off and the red light remains on. How much to replace light???????
  • mrsvicky32 Nov 10, 2008
    I have the same problem...had the TV for one year. It sounds to me like it is the lamp. I get a black screen with sound but no picture. It is not a cheap TV by any means...I would have hoped it would have lasted longer!
    How much to replace?
  • gcorvette54 Jan 25, 2009
    I have had the same problem for 2 two yrs and this is my 3rd go round. I bought it through Best Buy. Only a Yr to repair from Miz. and then you should be an extend warrenty for another 150 per year for 3 yr max. These units are notorious for this problem. About $1,500 to repair lights. CALL MITZUBISHI AND COMPLAIN AND SCREAM...Maybe we can have a Class Action Law Suit.
    gcorvette54@charer.net
  • Anonymous Feb 09, 2009
    Me too! After 11 months the lamp went...it has been 3 months and the lamp has gone again....
How much does the lamp light cost. Where do we purchase this??????
Posted on Oct 01, 2008
Time to replace your lamp.  The very same thing happened to me.  According to the manual you should receive a warning on screen but I didn't.  The day it happened I did notice the tv was very dim for a bit when I first turned it on in the am.  It is an easy fix and you can do it yourself.  Expect to replace it anywhere from 1 to 1/2 years.  If it's under a year I think it would still be under warranty.  However for me after replacing the lamp, the fan is making a lot of noise and the techs want $200 to fix it.
Posted on Oct 21, 2007
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Mitsubishi dlp
which of the three lights is flashing red?Let me know and I will assist you with the issue.
Mar 21, 2013 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
We have a Mitsubishi 65 inch dlp hd 1080p and we had a bad storm but we do have a surge protector on the tv. When we went to watch the tv after the storm it turned on fine but the dish had to reboot. After...
Something died in there - perhaps a capacitor or a solid state device just blowing and cracking into pieces. happens. Open up the set and see if you can spot it around the power supply area.
Aug 30, 2017 | Mitsubishi WD-62525 62" Rear Projection...
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns...
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
May 09, 2010 | Mitsubishi WD-65733 65" HDTV
Powers off and the lamp light goes red
The lamp will sometimes not turn dark before they start to go out. The life on these lamps are usually a year to a year and a half but, depending on when you purchased it in 2008 it may still be in warranty the lamp has 1 year on it.
Jul 28, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi 65" DLP HDTV, Status light is red, no picture
Check your lamp; it may have blown. Sound, no picture and a red light are classis signs a lamp has failed.
Feb 02, 2009 | Mitsubishi WD-62528 62 in. LCD Television
How do I reset lamp timer on Mitsubishi DLP TV?
I cant find the solution to reset my lamp hours, I replaced it, unplugged the tv like i was supposed to to. Its not reset. I have a 73" 1080p ...wd 73831 series
Sep 18, 2008 | Mitsubishi Diamond WD-65831 65" Projection...
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
275 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
