Question about Linksys Wireless-G Broadband Router
Wireless G broadband router
Normally we get connected at 54 mbps, but lately we have a hard time maintaing a connection, we we do connect its a really slow connection, and doesnt last long, gets disconnected.
  • 49 Answers
Please go to www.linksys.com/download and download firmware version of your router. For manual upgrade call linksys at 18003267114 or check out other linksys numbers.
Posted on Oct 15, 2007
SOURCE:
How do i upgrade to78mb ?
Do you mean you are an Xfinity (Comcast) user?
Anyway, you might have some luck calling Comcast and asking them for a higher-bandwidth service, but really if you're connecting to your router over a wireless channel that will be your bottleneck since the 802.11g standard for wireless networking supports a maximum bandwidth of 54 Megabits per second (Mbps).
Jul 29, 2014 | Linksys WIRELESS-G WRT54GS 802.11G...
The wifi is going 54 mbps but should be 100 mbps all cords are plugged-in properly what do i do?
wireless speed depends upon the wireless card that is installed on your computer...
if your computer have a
802.11 b/g card, it will connect at 54 mbps speed (That is the maximum speed at which the wireless can connect to the router)...
802.11 n card, it will connect at 150+ mbps speed...
Feb 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
My router will not connect to my internet modem
you most connect through the ethernet port then you need to make sure you have broadband line showing workins (ADSL OR CABLE)
hope this helps
Nov 28, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
Can only get a 10 meg when connected via cable to srx 200
The speed of your wireless adapter maybe up to 54 Mpbs only, check the wireless adapter that you have if it is 802.11 G its set to 54 Mbps only however if your using 802.11 N the speed of the adapter is around 300 mbps of connection.
There's a settings on the router that you can lock WAN port speed to around 10/100/1000
Note: To have a 300 Mbps of connection you should set the wireless settings of the router to WPA2 and AES with bandwidth of auto 20/40
Mar 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Connection problem
It sounds as if either the router is not set at enable DHCP which gives your pc's wireless adapters an automatic assigned ip address, so check in the routers settings via your web browser normally by typing 192.168.2.1 and check that DHCP is enabled and look in the menus and see if the transfer speed is set correctly at 54 mbps, the same as your wireless adapters. Also go to your wireless network adapters in network connections in control panel, right click on your wireless connection icon and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok it and close window. The problem with 'pre n' routers is that this setup was released before the alloted 'N' type transfer speeds and required firmware, hence named 'pre n' and can be quite troublesome at times. If you go through the above proceedure they should all connect, but you must also check in my computer, right click then click properties and look at the computer name tab and check that all the pc's are set at the same workgroup name, normally 'workgroup' or 'mshome', otherwise each pc will not be able to see each other.
Jul 05, 2007 | Belkin Wireless Pre-N (F5D8230-4) Router...
NetGear Super G 108Mbps Wireless Firewall
If you are connecting wirelessly, then it's more than likely that your wireless card or usb dongle cannot connect as you router is probably set at 108 mbps. Your receivers are more than likely only capable of connecting at 54 mbps so change the streaming rate on your router to 54 mbps. This will not alter your internet connection speed as the 108 mbps only refers to the rate of streaming speed on your local area connection (from one pc to another)
Dec 30, 2006 | NetGear Super G 108Mbps Wireless Firewall...
In my new router getting less speed in wireless connection than when connected with a cable.
The 54 mbps refers to the stream rate from the router to the wireless reciever, the 100-110 kbps you refer to is the connection speed to the internet. These are two different things, if you were transfering files from one pc to another it would transfer at a max speed of 54 mbps. If you connect via a cable it would be 100 mbps. Your internet speed depends on your isp server your downloads will be less than 256kbps, with even less upload speed.
Dec 19, 2006 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G Broadband Router Logo
190 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
