Question about Kenmore 24032\24036 Top Load Washer
Kenmore direct drive,will not spin.
I took the washer apart to check the coupler and it looks alright. the washer goes through all the cycles , it drains the water out but will not spin to remove water from cloths.
    President:
  • 1,136 Answers
Hi, If the coupler is ok, you might have a spin basket drive going bad. You can try and put the machine in spin, put something in the lid switch activator slot and then try and start the tub with you hand.
I hope this helps you. Please let me know if I an assist you further.
Thanks
Vic
Posted on May 14, 2009
Kenmore washer oil leak
That is a transmission issue. Once it starts leaking oil. The gearcase needs to be replace along with the clutch and coupler. The repair should run you about 150-250 dollars in parts. But I do believe it is worth the repair. If you are above average with tools and repair it can be done in about 30-45 mins and will allow you was to last longer than any new washer you can buy.
Apr 30, 2017 | Washing Machines
The belt came off of the washing machine so it will not spin. We have a kenmore 80 series the model # 110.29852991. I just need to know where it goes back on please. A diagram if possible. Thanks
this unit does not have a belt,,this model number is for a direct drive washer,,,you have a coupling thats in between motor and transmisson..it looks like the picture enclosed..if we are talking about some other part ,,repost...onthejob5130_5.jpg
Sep 11, 2011 | Kenmore Washing Machines
My Kenmore 11022642 model goes thru all the cycles ok, but when it gets to the spin cycle I have to give the drum a push to get it going, it will spin with very light loads. I checked the lid switch for...
The transmission in your washer is going bad. It is not creating enough power to get up to high speed without assistance. I would start looking for a new washer. The transmission is one of main parts for the washer and it will cost over 400 dollars to fix it.
Jul 11, 2011 | Kenmore 22642 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
WILLNOT SPIN OR AGGITATE/IT WILL DRAIN
Just because the rubber part of the coupler isn't shreded doesn't mean that the plastic parts are not broke... There are three stems that protrude from the plastic parts of the drive coupler,and mesh with the rubber section of the coupler... the stems may be broke off... If you smell rubber burning then I would say almost 99% of the time it's a bad drive coupler...If the coupler is not broke and the rubber section is alright then you have a bad transmission... Most likely the main drive gear is bad... Since you said that you can spin the tub by hand, indicates that the brake system is alright, and nothing is caught between the inner and outer tubs... You can rule out a lid switch problem, cause the washer would agitate even with a broken lid switch, but it would not spin..since the machine make any kind of different sound when you run it Like a high pitch squeal or grinding noise?
check the lid switch see if it's not broke... wasn't the lid switch, but I got to thinking it will agitate at the first part of the wash cycle, but when it goes into the slower speed wash, if your lid switch is broke, then it won't agitate or spin...
Feb 10, 2009 | Kenmore Washing Machines
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Motor is humming loudly.
Motors hum, and your right, it could be no worse than normal.
I would be suspect that there is a gear stripped in the gearcase, since this is a direct drive washing machine.
Reassemble the motor back onto the washer. Run it through a cycle manually (rotate the timer by hand) until the motor turns, then look to see if it's turning. If it is, or even more so, if it pumps water out of the tub, then it is probably the stripped out gearcase.
Reply with you findings and more advice.
Jan 23, 2009 | Kenmore 24872 Top Load Washer
I have an older model Kenmore washer - stopped spinning and aggitating - I took the control panel off, how do I reach the belt?
Your problem may not be a belt some Whirlpool built Kenmore washers are direct drive and have a coupler instead of a belt. The coupler is located on top of the motor. It consists of three parts two with prongs and one with holes for each of the prongs. If this is broken or badly worn the washer will not agitate or spin. Good luck. Oh the drive coupler part number is 285753A.
Jan 08, 2009 | Washing Machines
Top-loading, direct drive Kenmore model won't do spin cycle
In other words it pumps out but when it goes into spin nothing happens. The first thing to check is to remove the tranny(get the agitator out) take the 3 bolts loose and slide out the tranny(no need to get the tub out) Take a look see at the plastic brake release collar mounted on the bottom of the basket drive. The ear will break off and thus no spin.3ef16e8.jpg If that looks ok let me know...
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore 110.92195110
those parts come as a complete kit. order a brake assembly.
Jan 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
115 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
