Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
After using the kemore vac it shuts off depending on how I m pulling on the tube part, it seems like there's a short where. Any help Thans,Steve the canister connects to the suction tube
  • heydude830 May 14, 2009
    Thanks for your help with the Kenmore vacuum.
    I really appreciate it, I'll take a look at the handle and see if there's anything obvious.
    If it's not too much trouble I'd like to see the diagram.
    Thanks again your the best,
    Steve
  • 43 Answers
This is a very common problem on your series of Kenmore canister vacuums. It is the result of a part inside the handle of the hose (where you would have your hand) which has broken and no longer properly supports and keeps in place the electrical receptacle that feeds electricity from the canister to the power head. If you provide a model number, I can provide an exploded parts diagram which will show you the likely culprit.
Dave
Posted on May 14, 2009
  • Dave May 14, 2009
    The probable broken part is shown as #5 in this diagram: http://www.sewvac1.com/Kenmore_Hose.pdf. There should be some plastic that's broken which normally keeps the receptacle (shown as #12) in place. Without the supporting plastic in the handle, #12 has some "play" allowing it to recess into the handle just enough to prevent a sure connection. Also, I checked on Sears' web site and they do show the model number as valid, but when clicking on the exploded parts link, it then states there is no such model. Bottom line is if you want to order the part from Sears, you'll have to do it by phone instead of online. The diagram I show in the link is from a different but very similar model, so I hesitate to give you the part number for the item because I can't be 100% certain it's exactly like yours. Good luck, Steve.
    Dave
Hey Dude! & Dave! I am having the same problem with an older model 116 (whispertone). This is what I came up with.
What I did to fix it was take it all apart (and I mean everything) wipe it all down and carefully put it back together again. That seems to have fixed the issue. Theres a sensor at the bottom of the hose where it attaches to the canaster. I couldn't get it off the house initially but with some elbow grease I could and I found the sensor covered in gunk. Not sure if this was the real issue, but it helped!
Posted on Nov 03, 2015
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
How to take apart shop-vac tubes
Twist and pull? Beat it like it owes you money? Heat the outer part?
Apr 02, 2013 | Shop Vac Vacuums
I have two Electrolux Central Vacs. One is not working. Is there a reset button
If this is a CENTRALUX metal bodied 1590 series vac vac there is a reset breaker on the side of the motor housing of the vac. Depending on the age of the vac there is also a filter lockout switch . If you are using a cartridge filter and it is misaligned and drops down the switch will shut the vac off to prevent motor damage. Check those two items. The internal filter must be fully inserted so its twist lock/washer device can rotate holding it up in place. Then take a pair of insulated pliers and short across the low voltage terminals where the wiring system enters the top of the vac . If the vac starts, it is fine. If not your problem lies in the motor , the relay or the filter lockout switch.
If you have a plastic bodied Electrolux, a recent model the test procedure is the same but there is not the same lockout for the filter
Next test the nearest inlet in the house. If it fails to start you have a break in your internal wiring, possibly at a connection or a an inlet which may have a loose wire connection behind the wall. Post back with your results and if you have more questions. If so post the model #
Oct 28, 2009 | Electrolux Central Vacuum
Nutone CV556 Vaccuum Cleaner -Continuously running
Start with this. Unplug the vac to shut off, then disconnect the low voltage wiring at the vac.Plug the vac back in. If the vac still runs you have an internal short on the relay or wiring inside the vac.
If the vac stops then the vac and final wiring is OK and the problem is in the wiring in the house.
Have you removed any inlets for painting or had any renos done or pictures hung. If so undo what you did last. If inlets were disturbed remove them and look for low voltage vac wires touching metal backing plates in the wall or touching the inlet mounting screws.
If you have done a reno or hung pictures you may have pierece the wire for the vac creating a low voltage short which will keep the vac running until removed. I have seen this happen with freshly installed 1/4 round molding along a baseboard
Sep 07, 2009 | Broan-NuTone CV556 Cyclonic Bagless...
I need to replace the cord. There is a short near the housing.
hi may i suggest ? if you wish to renew the complete cord/wire? why not fit a longer length to facilitate more reach thro different rooms from the preferred wall socket ? the problem of short /breakage of wires within outer sleeve near casing is common on lots of vacs it is not a difficult job to replace if you are competant with wire and colour codes remove the access cover where wire enters vac then observe the attachment of each wire ? then disconnect faulty cable transfer the rubber tube that is normally fitted at entry point to vac at this point to new cable remove outer sleeve of new cable same length as old cable to reveal the inner wires then connect to vac sockets resecure cable to vac as previous dont forget the rubber tube? refit entry cover and fit a new 3 pin plug bs kite marked ? then away to vac the rooms? hope this helps
Oct 20, 2008 | Hoover Vacuums
Central Vac does not shut off
Sounds like the relay that is in the central vac unit is stuck to the ON position. When you plug it back in..does it start right up ? If so.. You should be able to disconnect all the receptacle feeds to the central vac unit at the central vac unit to determine which one ( if any) is calling for the vac to stay on.. if none are.. then it is internal to the vac and may be a stuck relay... Hope that gives you some ideas to check...
Aug 28, 2008 | Vacuums
Clean water runs right out of by the brushes.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=569188
Posted by ripp73 on May 04, 2008
I have taken the cover off and the tubes are all connected and I also checked the tank and it operates fine. I was wondering if i could have a bad gravity solution valve or something else. Thanks Steve
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You may have a bad water pump, bad gasket, the water release valve could be broken, or the water tank is not sitting on the opening properly or the trigger assm is not closing properly. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 04, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
321 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
